Ron Dittmer's Compilation Of Personal Tips & Tricks
  • 12 Replies
  • 57500 Views
  • 5715
« on: January 19, 2018, 08:55:49 am »
Greetings To The Phoenix Cruiser Family and To Those Considering A Phoenix Cruiser
Here is my compilation of Tips and Tricks I have written since Phoenix started the forum in early 2009.  I put this together to make it easier for myself and others to find them.  Maybe you will find some interesting and applicable to your PC or other motorhome.
Keep in-mind that my Tips and Tricks apply directly to a 2007 PC built on a 2007 Ford E350, model 2350 with no slide out.  Some will not be applicable to different models and more recent models.  Also understand that I am a miser by nature, always trying an affordable alternative to repair or improve things.  They are not necessarily the easiest method and in some cases, not the best method.  They are simply a low cost method that worked for me.
If you plan to purchase a brand new PC and you wished a new one had something I modified on my rig, ask the factory.  They can accommodate various special requests.
1) Ron's Tips For Class C /B+ Shoppers
http://forum.phoenixusarv.com/index.php/topic,1911.0.html
2) How To Add A Link To A Website, In Your Post Or Reply
http://forum.phoenixusarv.com/index.php/topic,2697.0.html
3) Improvements & Enhancements, 2007 PC-2350
http://forum.phoenixusarv.com/index.php/topic,8.0.html
4) Resolving An Irritating Squeak In Cabinet Above The Cab
http://forum.phoenixusarv.com/index.php/topic,3024.0.html
5) Doubling Drawer Storage Of Galley Base Cabinet
http://forum.phoenixusarv.com/index.php/topic,1751.0.html
6) So Your Ford Died And Won't Start. First Try This.
http://forum.phoenixusarv.com/index.php/topic,1141.0.html
7) If Struggling With Your 2350 Rear Corner Bed, Consider This
http://forum.phoenixusarv.com/index.php/topic,1695.0.html
8) How To Avoid Tow Vehicle Bucking
http://forum.phoenixusarv.com/index.php/topic,1697.0.html
9) Rear Compartment Lined With Outdoor Fabric
http://forum.phoenixusarv.com/index.php/topic,2467.0.html
10) A Low Cost Heavy Duty Rear Sway Bar For The Do-It-Yourself-er
http://forum.phoenixusarv.com/index.php/topic,155.0.html
11) Evaluation Of Tire Gauges For Accurate Readings - Reduce Risk Of A Tire Blow-Out
http://forum.phoenixusarv.com/index.php/topic,2798.0.html
12) Solved Chronic Microwave Oven Loosening Then Rattling
http://forum.phoenixusarv.com/index.php/topic,2486.0.html
13) Windshield & Van Door Window Sun Shades - Cheap, Effective, Easy To Use & Store
http://forum.phoenixusarv.com/index.php/topic,2513.0.html
14) Ever Wonder What A No-Slide-Out Dinette Looks Like?
http://forum.phoenixusarv.com/index.php/topic,2842.0.html
15) How To Determine If Your Ford Is "Keyless Entry" Ready
http://forum.phoenixusarv.com/index.php/topic,1145.0.html
16) More 12V Outlets For Us With The Older Ford Chassis Design
http://forum.phoenixusarv.com/index.php/topic,2233.0.html
17) Adding Features To Our Older Style 2007 Control Panel
http://forum.phoenixusarv.com/index.php/topic,2234.0.html
18) Inspect Your Roof, It Might Need A Touch Of Caulk Here And There Like Ours
http://forum.phoenixusarv.com/index.php/topic,2239.0.html
19) What Is That Banging I've Been Tollerating For The Past 3 Years?
http://forum.phoenixusarv.com/index.php/topic,232.0.html
20) Need The Strength Of "THE HULK" To Work Your Shower Head? If So, Read This.
http://forum.phoenixusarv.com/index.php/topic,2241.0.html
21) Does Your A/C Unit Run Exceptionally Noisy? If So, Read This
http://forum.phoenixusarv.com/index.php/topic,2570.0.html
22) On-Vehicle Tire Repair
http://forum.phoenixusarv.com/index.php/topic,1038.0.html
23) An Affordable Roof Vent Cover For People On A Budget
http://forum.phoenixusarv.com/index.php/topic,2939.0.html
24) Is Your Hot Water Not Working On 110V? If So, Read This
http://forum.phoenixusarv.com/index.php/topic,92.0.html
25) Hand-Held Bug Zapper, Fun & Effective
http://forum.phoenixusarv.com/index.php/topic,1850.0.html
26) Tuning-Up Your Heavy Duty Stabilizer Bars
http://forum.phoenixusarv.com/index.php/topic,2991.0.html
27) Converting Interior Lighting To Low Power Warm LED Lighting, Very Affordable
http://forum.phoenixusarv.com/index.php/topic,2186.0.html
28) Reinforcing Your Norcold Fridge Door Hinges
http://forum.phoenixusarv.com/index.php/topic,2187.0.html
29) Those Two Screws In The Middle Of The Entry Door Threshold
http://forum.phoenixusarv.com/index.php/topic,77.0.html
30) How To Test Your Suspension. Does It Need Heavy Duty This & That?
http://forum.phoenixusarv.com/index.php/topic,2094.0.html
31) When Was The Last Time You Checked Your Roof A/C Cover?
http://forum.phoenixusarv.com/index.php/topic,2932.0.html
32) Converting From Two 12V Batteries To Two 6V Batteries
http://forum.phoenixusarv.com/index.php/topic,2092.0.html
33) Ford Engine Power-Robbing Assembly Mistake, Easy For Anyone To Check For
http://forum.phoenixusarv.com/index.php/topic,2931.0.html
34) Putting Up Awning While In A Real Bad Storm
http://forum.phoenixusarv.com/index.php/topic,615.0.html
35) Low Cost Macerator Pump Replacement (Saved A Pile Of Money)
http://forum.phoenixusarv.com/index.php/topic,2086.0.html
36) Tip On Battery Care
http://forum.phoenixusarv.com/index.php/topic,1433.0.html
37) Conserving Battery Reserves Without Shore Power
http://forum.phoenixusarv.com/index.php/topic,73.0.html
38) Repairing Older Kitchen Faucet, Leaks Under Handle When Water Is On
http://forum.phoenixusarv.com/index.php/topic,2906.0.html
39) Adding Storage Tube For Backup Manual Sewer Dumping
https://forum.phoenixusarv.com/index.php?topic=3332.0
40) Stabilizing Dinette Table (Table With Two Poles)
https://forum.phoenixusarv.com/index.php?topic=3365.msg28453#msg28453
41) Adding A Kitchen Towel Rack
https://forum.phoenixusarv.com/index.php?topic=3379.0
42) So You Are Thinking Of Buying A Motor Home
https://forum.phoenixusarv.com/index.php?topic=3555.0
43) Replacing Shock Absorbers That Failed And Why
https://forum.phoenixusarv.com/index.php?topic=3580.msg30529#msg30529
44) Fresh Water Accumulator Tank Benefits and Installation
https://forum.phoenixusarv.com/index.php?topic=3592.msg30812#msg30812
45) Affordable Replacement Mattress, Made To Any Size And Shape
https://forum.phoenixusarv.com/index.php?topic=3796.0
46) Installing Softer Front Springs For A More Comfortable Ride
https://forum.phoenixusarv.com/index.php?topic=4168.0
47) Added A Propane Tank Shield From Rear Tire Splash.
https://forum.phoenixusarv.com/index.php?topic=4422.new#new
48) Replaced Steel Wheels With Alcoa Alloy Wheels
https://forum.phoenixusarv.com/index.php?topic=4360.0
49) Loaded The 5-Star Tune
https://forum.phoenixusarv.com/index.php?topic=5018.0
« Last Edit: May 29, 2025, 08:08:46 am by Ron Dittmer »
KB9OMH
  • 168
  • PurchDate: 3/26/13
  • IntColor: Maple
  • ExtColor: Sterling
Re: Ron Dittmer's Compilation Of Personal Tips & Tricks
« Reply #1 on: January 19, 2018, 10:18:44 am »
     Thanks for the tip page, have enjoyed the reports since 2013 when I got my PC 3100. Have put some to work myself. Hope to meet you someday. I will be going to the rally in Sept. hope to see you there. Keep up the good work
  • 5715
« Reply #2 on: January 19, 2018, 10:51:55 am »
Thank you Jim for your reply.  It is good to read that people find my Tips & Tricks useful.
I have never attended a gathering of PC owners......I am so "itching" to attend one.
The trouble with Irene and me is that it is so hard to get out with our PC.  We average one 3 to 4 week RV trip a year that is squeezed into our busy lives.  I thought retirement would open up opportunities of which it has with our other vacationing methods like cruise ships and world travel.  I did end up maintaining my profession on a part-time contract basis which further complicates trip-scheduling.  At least my work has been funding our travels so far.
Maybe one of our RV trips will one day fall within a PC gathering, both schedule and location.  It would be awesome to meet fellow PC owners.
KB9OMH
  • 168
  • IntColor: Maple
« Reply #3 on: January 19, 2018, 11:19:38 am »
     I understand, I retires 15 years ago and the started working part time doing what I did before, but I put in a conduction on my contract, that if I wanted to going RVing then I could go without any problems, Been with the save company for 14 years  and they still are OK with the agreement we made. So good luch on getting more travel time. I live in Peoria, so if you ever find yourself near by let me know and we can meet.
  • 5715
« Reply #4 on: September 09, 2018, 08:32:09 pm »
Added: Sewer Hose Storage Tip
« Last Edit: September 10, 2018, 10:10:52 am by Ron Dittmer »
  • 5715
« Reply #5 on: September 10, 2018, 10:10:30 am »
Added: Stabilizing Dinette Table (Table With Two Poles) Tip
  • 5715
« Reply #6 on: September 18, 2018, 12:30:47 am »
Added Kitchen Towel Rack
« Last Edit: September 18, 2018, 12:36:33 am by Ron Dittmer »
  • 5715
« Reply #7 on: March 06, 2019, 02:58:54 pm »
Added "Replacing Shock Absorbers That Failed And Why"
  • 5715
« Reply #8 on: March 20, 2019, 10:14:40 am »
Added "Fresh Water Accumulator Tank Benefits and Installation"
  • 5715
« Reply #9 on: September 10, 2019, 11:28:24 pm »
Added "Affordable Replacement Mattress, Made To Any Size And Shape"
  • 5715
« Reply #10 on: August 30, 2020, 11:25:47 pm »
Added: "Installed Softer Front Springs For A More Comfortable Ride"
  • 5715
« Reply #11 on: May 18, 2021, 07:28:56 pm »
Added on 5/18/2021 to the original post:   Added A Propane Tank Shield From Rear Tire Splash.
  • 5715
« Reply #12 on: November 03, 2023, 12:41:55 am »
I added a few more at the bottom of my original post.
