waterpump switch light
  • 9963 Views
jim farley
  • 6
  • PurchDate: 4/22
  • IntColor: taupe
  • ExtColor: brown/gold
« on: June 23, 2022, 02:44:53 pm »
we have a 2013 3100 cruiser and 3 water pump off/on switch's, at each one i red light stays on all the time, no matter what i do to the rocker switch, any fix idea's??
Engineerlt
Re: waterpump switch lightn't
« Reply #1 on: June 23, 2022, 07:02:36 pm »
Hello I guess you'll have to trouble shoot all 3 water pump switches, 1 at the sink, 1 in the bathroom and one at the macerator pump controls. I would probably start with the one at the macerator pump controls as its exposed to moisture/humidity. If your sure they are all off that is. The wiring is pretty simple I would say that its a switch issue as you are not saying the pump is still running. The Mpx low side latching controller I wouldn't think is the issue if you can still start and stop the pump with the switches. Here is a link to the latching controller https://intellitec.com/wp-content/uploads/2019/05/53-00145-100.pdf .  This has a wiring diagram that shows how it works. The switches control the ground side of the circuit. On my 2552 the Mpx low side latching controller is located under the passenger side bed. The latching controller is at the bottom of the picture.
I would think you could simply disconnect the wires from each switch one at a time and see when the light goes out, That will probably be the faulty switch.
Very Respectfully
Lance
« Last Edit: June 23, 2022, 08:19:16 pm by Engineerlt »
jim farley
  • 6
  • PurchDate: 4/22
  • IntColor: taupe
« Reply #2 on: July 01, 2022, 02:08:34 pm »
i found it Lance, thanks for the help, that Mpx Low Side Controller was melted, 58.00dlls to replace the part with 2 screws myself, light is off, guessing prior owner left waterpump on all the time and it got hot
Engineerlt
« Reply #3 on: July 02, 2022, 07:12:01 am »
Wow didn't figure it to me the MPX latching relay. I am however happy you figured out the issue. Look forward to seeing you out on the road. Very Respectfully Lance
« Last Edit: July 02, 2022, 09:08:46 am by Engineerlt »
