Roof Sealant
  • 8 Replies
  • 19448 Views
tdbeltz
  • 5
  • PurchDate: May 2018
  • ModelYear: 2009
  • IntColor: desert
  • ExtColor: desert
Roof Sealant
« on: August 25, 2021, 01:07:42 am »
Has anyone used Dicor Fiberglass RV Roof Coating on their roof?  If not are there any other recommendations?
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
Re: Roof Sealant
« Reply #1 on: August 25, 2021, 09:57:42 am »
Has the paint come off your roof or are you making it look nice?  Paint would be a good choice. Of course that is my opinion only.
Re: Roof Sealant
« Reply #2 on: August 26, 2021, 08:20:33 am »
The roof is not painted. It is thin fiberglass sheet. All I do is keep it clean.
Engineerlt
Re: Roof Sealant
« Reply #3 on: August 31, 2021, 09:48:26 am »
Here is a couple pictures of my roof after it was sealed with Flex-Armor. I have 0 leaks from the roof and guaranteed for life to never leak. This coating is 1/4 inch thick and tuff as nails. It is sprayed on hot and dries in roughly 6 seconds. They removed the vents, old caulk, A/C's etc.  Then they sprayed the roof and also added some aluminum uni-strut to mount my solar panels. I can't say enough about this coating.  The company in Sarasota FL. that installed this on my PC was also installing it on the city buses and school buses.
CDWall
  • 36
  • PurchDate: 01/2013
  • IntColor: Brown
Re: Roof Sealant
« Reply #4 on: August 31, 2021, 10:58:09 am »
This looks awesome! How does it hold up to dirt afterward? Do you mind saying how much it costs?
Engineerlt
Re: Roof Sealant
« Reply #5 on: September 01, 2021, 08:31:03 am »
It ran around $4500, but you never have to caulk or worry about a leak from the roof ever. It also prevents most branch strikes from doing any roof damage as well.  That's with in reason, if a tree falls on it obviously you may have some issues. The coating comes down over the the front and rear caps also down over the seam on the sides. I park my PC next to my workshop outside and don't worry about roof leaks. I think it was worth every dollar spent on it.
CDWall
  • 36
  • IntColor: Brown
Re: Roof Sealant
« Reply #6 on: September 02, 2021, 04:47:00 pm »
For some reason I thought it was about that much.
But do you think it keeps cleaner than the original? Like does dirt stick to it?
Engineerlt
Re: Roof Sealant
« Reply #7 on: September 03, 2021, 05:54:30 pm »
It can get dirty, but it is easily cleaned.  Soap and water and it is as good as new.
RV Quest
  • 5
  • PurchDate: 9-20-17
  • ModelYear: 2005
  • IntColor: blue
  • ExtColor: white
Re: Roof Sealant
« Reply #8 on: October 24, 2021, 10:03:57 pm »
I used it on my 2005 year, 2100 model. My fiberglass roof was showing strands of raw fiberglass. I fully cleaned the roof and let it dry, then taped off no paint areas. I used a 1/4" smooth surface roller for the large areas and a paintbrush on the small arears. I used less than 1 gallon of the paint. I did not prime, but Ithe instructions recommend it.It has been 2 years and it still looks great with no peeling. The roof is easier to clean and stays clean longer.
