Mascerator hose durability
  • 7 Replies
  • 299 Views
Dystevens
  • 11
  • PurchDate: 8/8/2025
  • ModelYear: 2021
  • IntColor: Light Oak
  • ExtColor: Gray
« on: October 25, 2026, 06:59:01 pm »
Again I am a fairly new PC owner and have only had to dump using the Mascerator twice so far. First time was at  a RV park and had no problems. Second time was last week at home while preparing to winterize. My previous motorhome was an Itasca Suncruiser. For dumping at home I always used a portable Mascerator that attached to the normal dump connection on the motor home and was powered by 12 volts. I would attach a garden hose to the Mascerator and run the other end through a bathroom window directly into the toilet. I thought I could do the same routine with the built-in Mascerator and hose on the PC. I thought that was what the garden hose fitting on the end of the Mascerator hose was for. That turbo pump must produce a lot of pressure because as soon as I turned on the pump, the Mascerator hose exploded in two places. Fortunately I was only emptying mostly water and antifreeze and everything was outside or it could have been really messy. This is a used 2022 PC but the Mascerator hose looked good and worked fine at the RV park. Has anyone else had a problem with the Mascerator hose springing a leak?
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • IntColor: Maple
  • ExtColor: White/Sage
Re: Mascerator hose durability
« Reply #1 on: October 25, 2026, 11:30:41 pm »
In a pinch I have done the same.. I have a half bath not far from the driveway and emptied the tanks in the same manner you described. I was worried about it leaking, but all went well... At that point the hose was the original 10yo that came from the factory. I'm so sorry to hear this nightmare materialized for you. At least it wasn't terrible terrible if you know what I mean. .
Since that, I have replaced the hose... I actually bought 2 and they came with a coupler to join them end to end.. And I had a sewer dump next to my driveway added.. I was lucky that the main was about 10ft away and needed cleaning out, so I had the plumber dig his hole where it served the RV best. I covered the 4 inch cap with a sprinkler valve niche and nobody has ever noticed it.
The only thing I can think of is that I used a  25ft 3/4 inch garden hose, with the thought that a 1/2 inch and/or longer hose might constrict the flow to much. What size was your garden hose?
Larry
« Last Edit: October 26, 2026, 11:19:17 pm by LRUCH »
Larry
« Reply #2 on: October 26, 2026, 03:16:48 pm »
An interesting subject with an interesting reply.
As LRUCH wonders, the diameter of the garden hose could influence the back pressure in the macerator's stinky slinky.  A narrow 1/2" garden hose may restrict flow enough to expand the slinky to the point of failure.  A wide 3/4" garden house might avoid a build-up of damaging back pressure to the macerator's stinky slinky.
FWIW: Our original 2007 macerator's stinky slinky is still in operation though it had sprung two pin-hole leaks over the years.  Upon discovery, I sealed them using a dab of silicone caulk which has been lasting many years, so the caulk seems to be a viable method of repair.
« Last Edit: October 26, 2026, 03:19:48 pm by Ron Dittmer »
Dystevens
  • 11
  • ModelYear: 2021
  • ExtColor: Gray
« Reply #3 on: October 27, 2026, 01:08:17 pm »
The garden hose I used was one I bought special for the job. Contractor grade 3/4”. I have used it many times before with the portable Mascerator on the other motorhome. I have got to say the turbo Mascerator seems to generate much more pressure. Seriously considering buying a second 1&1/2 inch Mascerator hose for future uses.
« Last Edit: October 27, 2026, 01:32:05 pm by Dystevens »
wideglide
  • 86
  • PurchDate: 6/2026
  • ExtColor: gray
« Reply #4 on: October 27, 2026, 01:45:18 pm »
When i installed my turbo 400s system i bought a 25ft hydraulic hose abrasion sleeve and ran the sanicon hose through it. Hopefullt it protects the hose from getting cut or if it ruptures maybe will contain the mess long enough to shut the system down.
« Last Edit: October 27, 2026, 01:50:33 pm by wideglide »
Dystevens
  • 11
  • ModelYear: 2021
  • ExtColor: Gray
« Reply #5 on: October 27, 2026, 06:13:35 pm »
I have seen those sleeves on some of the PCs. If I had one of those I might not have got sprayed when my hose ruptured. I got the old hose off today and am looking to replace it. Any suggestions on where to get a replacement. Should I order from Phoenix cruiser or just buy from Amazon. They have several that say they are compatible with
thetford Sani-Con Turbo 700 but the hose ends look a little different from mine. Would appreciate any suggestions from those of you that have replaced yours before.
wideglide
  • 86
  • PurchDate: 6/2026
  • ExtColor: gray
« Reply #6 on: October 28, 2026, 08:55:37 am »
Below is the Thetford part number. Examples from amazon for offbrand  and unitedrv for a thetford brand. Both look identical to mine on my turbo400. There are also aftermarket ones on amazon that already have the protective sleeve installed. Pulling the hose thru the sleeve was the hardest part of the job for me.
https://unitedrvparts.com/products/thetford-sani-con-replacement-macerator-hose-97521-1-1-2-diameter-21?variant=45365260681519&utm_source=google&utm_medium=cpc&utm_campaignid=20546546876&utm_campaign=PRO_Pmax_UnitedRV_Bamboo_CVR_Purchase_Misc.&utm_adgroupid=&utm_device=c&utm_network=x&gad_source=1&gad_campaignid=20550473035&gbraid=0AAAAAqMZvfTnBx8ECxMcRHRNXlTWOy2FU&gclid=EAIaIQobChMI3uDa3t3clwMVGkl_AB1gNRVTEAQYAiABEgIOPfD_BwE
Camperfan
  • 25
  • PurchDate: 04/26
  • Model: 2351
« Reply #7 on: October 28, 2026, 09:09:03 pm »
Buy genuine Thetford for the best quality!!
I bought the one from Amazon that was sold by United RV. It was 10$ less on Amazon vs at United RV’s website.
My Cruiser is a 2016, and I can see by the date sticker on the currently installed macerator hose that it is newer than my rig, so must have been replaced once already by the previous owner? I bought the genuine Thetford kit from United RV for a spare, and I store it inside the spare tire cover on the rear cap
