help
  • 7 Replies
  • 10034 Views
help
« on: May 19, 2011, 07:37:54 pm »
some one posted they purchased some kind of deflector for the heater. the ends where the heat comes out and are adjustable,
WHO DONE TAT ?????
Re: help
« Reply #1 on: May 19, 2011, 07:47:38 pm »
I also would be interested in the source.
Thanks.
Re: help
« Reply #2 on: May 19, 2011, 08:44:03 pm »
I put one on the bathroom outlet and it works great, the bathroom got too hot and now we can adjust it down and divert more to the front outlets.
I found them at two RV dealers parts departments in Reno.  One was a direct replacement by the same manufacturer, and the other woudn't work because it was for a smaller cutout and the screws went into the existing cutout not into the wood.  So check around to find the same brand, maybe take the old one with you.  It is an easy job, just remove the three screws and pull it out, the excess flex duct comes out with it so you can pull the duct off and put it onto the new outlet and replace the screws.
This is what it looks like, just turn the knob and the two flaps behind the grill close like a butterfly valve,  Oh, and it is two screws, not three.
« Last Edit: May 19, 2011, 09:01:30 pm by bobander »
Re: help
« Reply #3 on: May 19, 2011, 09:26:03 pm »
Just what I/we need.
Now all I have to do is find some.
Thanks Bob.
Re: help
« Reply #4 on: May 20, 2011, 12:11:23 am »
I seem to recall people on another forum complaining the adjustable leuvers rattle and also shut closed on their own, or was it open up on their own.  Something to watch out for.
  • PurchDate: May. 2014
  • ModelYear: 2551/2014
  • ExtColor: Cafe'
Re: help
« Reply #5 on: May 20, 2011, 12:22:55 am »
I put a regulated heater vent also in the bathroom and it does force more heat to the other outlets.  There are two types of these vents.  They both look the same in outward appearance and regulate with a knob.  But I have both because I found the first one worked OK until it got warm and then it closed off all air.  I found to use a wooden clothes pin placed between the louvers to set it and maintain the air flow I wanted.  I bought a butterfly valve one and found it did the same thing, so I use a clothes pin for that one also.  Curious if bobander is having the same experience.
Re: help
« Reply #6 on: May 20, 2011, 12:33:01 am »
Haven't had a problem with mine yet, it stays where I set it.
I checked the old one I took off and found info marked on it.  It is a Rotaire from dwincorp.com.  I checked their website and the dampered model is 3840R.
http://dwincorp.com/product_info.php?cPath=54&products_id=277&osCsid=d1d4a60d28cb527
Re: help
« Reply #7 on: May 20, 2011, 11:44:21 am »
Thanks Bob, be ordering a couple real soon, billy
