Replacing Air Conditioner
  • 1 Replies
  • 9875 Views
jg1199
  • 15
« on: September 19, 2022, 11:13:52 am »
2018 2552 w/ Dometic A/C
Our a/c keeps blowing the breaker. I watch the amps steadily go up after start up. After about 5 to 10 minutes the breaker trips. Sooo I am going to replace the whole unit with the quieter RecPro 15,000 unit. DYI of course lol
If you have replaced your a/c dyi any suggests or advice?
Thanks much. John
parkgt
  • 56
Re: Replacing Air Conditioner
« Reply #1 on: September 19, 2022, 10:10:37 pm »
Not sure which unit you have in mind, at least a couple of us have installed the RecPro/Houghton 3400 which is 13.5K.  It is much quieter and more energy efficient  Fits in the standard 14" x 14" opening with a better flange and mount than the OEM unit.
Wiring is easy enough.  Those units have a remote and no external wiring to the stock thermostat system; it has its own built into the ceiling section..  So you basically abandon those stock thermostat wires and put in a two wire thermostat (to replace the stock unit} with new wires run down to the furnace.
The most difficult part may be getting the 100lb unit up onto the roof.
