Sani Con Hose Leak
  • 19 Replies
  • 25033 Views
jg1199
  • 15
Sani Con Hose Leak
« on: June 18, 2021, 10:43:06 am »
My Sani Con Hose has developed a leak. Thank God for Rescue Tape! Now I'm trying to find a replacement. Any advice? PC parts takes forever to call back or just doesn't. I ordered one from Amazon but it was the 1 inch not the 1 1/2 one. I might try using the smaller one with reducers from 1 1/2 to 1. Any thoughts?
fandj
  • 345
Re: Sani Con Hose Leak
« Reply #1 on: June 18, 2021, 11:05:34 am »
I developed a leak in the Sanicon hose shortly after taking delivery of the new Phoenix.  The hole developed because of the way it was originally installed.  I also used the Silicone Rescue Tape hoping it would last until I got the replacement.  Phoenix provided me a replacement.  The hose is the larger Turbo Macerator model.  Knock on wood the Rescue tape is still working 4 years later and no leaks so I still have the replacement hose as a spare.
I would recommend staying with the larger hose as it will handle twice the flow at the same pressure drop thus significantly faster dumping.
I would think Phoenix may have the hoses in stock.  I am not familiar with the current PC parts ordering process.  PC took care of me when I returned the MH for warranty work.
  • 5717
« Reply #2 on: June 18, 2021, 11:16:19 am »
Our macerator hose developed a tiny pin hole leak years ago that I managed with a dab flexible adhesive that I believe is still holding up well.  I forget the brand of adhesive.  The pin hole is near the pass-thru to the macerator so my thought is that if or when the adhesive fails, simply cut off the hose at the leak, reattach, and live with a slightly smaller hose.  The hose has been plenty long...maybe too long, so shortening it a little is of no concern in my case.
« Last Edit: June 18, 2021, 12:20:58 pm by Ron Dittmer »
jg1199
  • 15
« Reply #3 on: June 18, 2021, 11:55:31 am »
Phoenix just called and is looking for a replacement. My leack is a split so I need to replace. If I can find the larger one than I will replace with that. I'm having no luck online.
Update: Phoenix said if they could get one their cost would be $350+. So I guess I'm going to try and modify the 1 1/2 inch outlet to fit 1 inch hose with reducers. We'll see...
« Last Edit: June 18, 2021, 02:44:03 pm by jg1199 »
fandj
  • 345
« Reply #4 on: June 18, 2021, 03:29:36 pm »
This company lists the hose 97521 for the Turbo Macerator.  https://www.adventurerv.net/hose-clamp-and-coupler-for-sanicon-turbo-p-41013.html
I don’t know anything about this company so I can’t speak for its reliability, etc.  Perhaps someone on the Forum has ordered from them and can share their experiences.  I just found it by Googling the part number.
As I recall when PC replaced mine in 2017 the price was about $70 so the price above ($92) sounds reasonable given the current shortage of RV parts.
« Last Edit: June 18, 2021, 03:33:44 pm by fandj »
jg1199
  • 15
« Reply #5 on: June 18, 2021, 05:26:29 pm »
Thanks out of stock. I spent the last two days on the internet. Everyone is out of Stock. Going to try the 1 inch hose with reducers and see what happens. Rinsed grey tank filled with just water on first try LOL
  • 450
  • PurchDate: September 2013
« Reply #6 on: June 18, 2021, 07:53:23 pm »
We bought a Roadtrek 2010 Class B in 2006 and it was our first experience with a macerator pump.  They have a one inch hose and it was never a problem.   I think I have posted here before, in one emergency far from home when a hose failed we bought a one inch landscaping pond hose from Lowes for $20 and used it for five years and still carry one for a spare.   So , yes, it will be a lower discharge but yes, it will work.   That price they quoted you  seems astronomical and says a lot to me.
This is not as flexible and good as the proper hose, but in an emergency.......     Also, I didn't realize until I looked it up for this post they also carry an 1 1/2 product.  I would think it would be even less flexible than a one incher.
https://www.lowes.com/pd/smartpond-Black-Pond-Tubing/1000596755
Joseph
  • PurchDate: 3/7/2015
  • IntColor: Tan/Cherry
  • ExtColor: Gray / White
« Reply #7 on: June 18, 2021, 08:23:44 pm »
I actually don’t consider $92 really out of line. Nothing about motorhome or recreational vehicles in general that’s inexpensive.  Murphy law says I just jinxed myself.  😳
  • 450
« Reply #8 on: June 18, 2021, 10:04:14 pm »
The original poster stated:
That is what I consider more than too high.  Did I read/interpret this incorrectly??
WillLloyd
  • 216
  • PurchDate: Feb/2017
  • IntColor: Pebble
  • ExtColor: Grey
« Reply #9 on: June 18, 2021, 11:14:41 pm »
$350 doesn’t sound right. We got one from Phoenix cruiser for like 60 bucks if I remember right
« Reply #10 on: June 19, 2021, 08:35:19 am »
A quick Google search for "97521 hose" shows the Thetford 97521 hose supposedly available at many online RV stores.
jg1199
  • 15
« Reply #11 on: June 19, 2021, 11:09:54 am »
Thanks so much to everyone. I finally found one. Hopefully it will arrive before we have to move on. The Rescue Tape is still holding🤞
Thanks again!
jim.godfrey
  • 292
  • PurchDate: October 2019
  • ModelYear: 2020
« Reply #12 on: June 19, 2021, 03:44:01 pm »
The $350 quote sounds more like a replacement macerator system?
jg1199
  • 15
« Reply #13 on: June 22, 2021, 11:09:11 am »
Update: the hose I ordered is now on backorder. Any suggestions on who might have one?
Dave at Phoenix said that was just for the hose. He thought it was outrageous
faiello
  • 98
  • PurchDate: 08/2019
  • IntColor: Graystone/Cherry
« Reply #14 on: June 22, 2021, 06:14:04 pm »
mobilemusthave.com is taking pre-orders and will be shipping July 2nd.
Frank & Beth
