Lagun Table
  • 11 Replies
  • 19435 Views
JSanford
  • 36
  • ModelYear: 2021
  • IntColor: Nightscape
Lagun Table
« on: April 20, 2021, 06:53:51 am »
I want to purchase a Lagun table and install it on the left hand slide (left hand sofa chair) of my 2552.  Has anyone done this?  If so, any tips on installation would be appreciated.
Thanks.
Re: Lagun Table
« Reply #1 on: April 20, 2021, 08:20:19 am »
Click on the search icon on the upper right -
and put 'Lagun Table'  in the search field.  Some good info. :)
Re: Lagun Table
« Reply #2 on: April 20, 2021, 08:42:08 am »
What Volkemon said.  There has been discussion of Lagun installation issue (with some photos of the Phoenix factory installation).
JSanford
  • 36
  • ModelYear: 2021
Re: Lagun Table
« Reply #3 on: April 20, 2021, 08:46:15 am »
Thank you.  I'm working with PC to get one ordered.  Pictures are a bit hard to visualize.  I want to mount on ride side of slide (looking at it).  Left side, sitting in it.
« Last Edit: April 20, 2021, 08:48:29 am by JSanford »
RonJ
  • 126
  • Ron & Pilar
  • PurchDate: 10/2020
  • ExtColor: Greystone/Custom
Re: Lagun Table
« Reply #4 on: April 21, 2021, 07:53:02 pm »
We have a 2552 also.  We have two lagun tables installed by the factory.  I'll probably remove the one on the right (sitting in the couch) since it blocks the lowest door in the pantry.  They're good sized, so one should be good enough.
RonJ
JSanford
  • 36
  • ModelYear: 2021
Re: Lagun Table
« Reply #5 on: April 21, 2021, 08:46:21 pm »
Thanks for the comment, Ron.  I thought maybe two might be a bit much.  I'm concerned how the left one (sitting in the recliner) is mounted.  Any chance you could take a picture of the lower mount.  If not, no problem.  Thanks.
Jim
RonJ
  • 126
  • Ron & Pilar
Re: Lagun Table
« Reply #6 on: April 21, 2021, 09:35:33 pm »
Photos
RonJ
RonJ
  • 126
  • Ron & Pilar
Re: Lagun Table
« Reply #7 on: April 21, 2021, 09:37:11 pm »
Photos 1 & 2 are on the left side.
Photo 3 is the right side with the table removed.
RonJ
Re: Lagun Table
« Reply #8 on: April 22, 2021, 12:00:26 am »
Do the screws for the left side table mount go through the metal slide room frame  underneath the wood trim too?  If so,  did they use short self-tapping screws ,or machine screws with thin welded on nuts to prevent interference with the seal when the slide is extended?  TIA
« Last Edit: April 22, 2021, 12:02:09 am by CalCruiser »
JSanford
  • 36
  • ModelYear: 2021
Re: Lagun Table
« Reply #9 on: April 22, 2021, 06:46:33 am »
Thank you so much for the pics.  As it has been said, "a picture is worth a thousand words".  I can also see how the mount could interfere with the pantry on the pantry side.  So, I am waiting on information from PC so I can order one.  Now I can visualize how it was mounted.  Thanks again.
Jim
RonJ
  • 126
  • Ron & Pilar
Re: Lagun Table
« Reply #10 on: April 22, 2021, 12:14:44 pm »
Your welcome for the photos.
Calcruiser:
The screws can not be seen on the other side. It appears the screws only go through the wood.
RonJ
JSanford
  • 36
  • ModelYear: 2021
Re: Lagun Table
« Reply #11 on: April 22, 2021, 04:58:25 pm »
Placed my order with PC today.  Now it's a waiting game and I'm not good at it.  LOL
