Maxair Vent Cover(s)
  • 18 Replies
  • 22134 Views
Re: Maxair Vent Cover(s)
« Reply #15 on: March 09, 2021, 08:45:51 pm »
I'd guess 2" steel tubing and insulation, 3/4" plywood floor....
Yeah, that was the guess I had when saying 2 3/4" before. Then I remembered the black plastic on the bottom.   And that the 4" bolts had plenty of thread showing.  Later models may vary.
« Reply #16 on: March 10, 2021, 09:02:23 am »
Bolting anything through the floor requires a massive mounting plate on the underside to adequately distribute the pressure applied to the plastic barrier and block foam insulation.
« Reply #17 on: March 10, 2021, 09:51:23 am »
Well...  HANGING things off the floor, under the rig, such as the LP tank and generator are excepted.  Adding things to the top, yes indeed. But dont panic if you look and there is no 'Big plate' under the 'Eurochair'.
I put 7 carriage bolts through the right side floor, between the coach door and passenger front seat.  I want to make a battery box that hangs there. LOTS of empty space, and a great spot for that weight.
Here is a photo of one of the bolts, and the 4 holes from the former seat, aka 'Eurochair'
Note that there was no big backing plate. Just washers.   The floor there is not 3/4" ply, 1 1/2 " foam and then plastic. Knowing there would be a seat there, the factory built up the same thickness (1 1/2")  as the foam with two thicknesses of solid 3/4 plywood. Under the 'top' 3/4 floor.  I might also add that installing that one new bolt was VERY different.  Drilling through it was much harder then the other 6. And snugging the nut down on the washer did not distort the black plastic at all when tight.
Gotta love thread drift... Maxxair vent topic turns into floor construction.  (exactly) roflol
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
« Reply #18 on: March 10, 2021, 10:08:20 am »
So the thread changed a little.  I started it and then ask you a different question.  No big deal.  Anyway I will just be replacing the existing bolts with carriage bolts for a flat floor surface to lay vinyl planking.  Thanks for the pics and floor info.  At least the plywood isn't 3/8" that was in one of my RVs for flooring.
