Maxair Vent Cover(s)
  • 18 Replies
  • 22132 Views
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
« on: February 19, 2021, 11:08:11 am »
I bought some vent covers for the 2 vents on my .  Problem I saw when I go up there is space to put them.  It was summer and couldn't stay on roof very long in Nevada.  Returned them and never bought anymore.   Have been trying to see picture(s) of PC's that have installed covers.
Thanks, Bob
I did use the search tool and really didn't see what I was looking for.
Re: Maxair Vent Cover(s)
« Reply #1 on: February 19, 2021, 01:22:35 pm »
On a 2006 2350.
Yeah, its dirty. Pine pollen has been insane this year.   Let me know if you need other pics.
« Reply #2 on: February 19, 2021, 01:45:10 pm »
I did the same using Fantastic Ultra Breeze (which those picts look like) except in the "smoke" color to block overhead lights in campground or Walmart.  They work GREAT!
« Reply #3 on: February 19, 2021, 02:22:43 pm »
You Sir, are CORRECT.  I did not note that the post referred to Maxair vent covers.   We looked at the Maxair, but I thought the back of this model blocks rain MUCH better.   And torrential rain is the biggest 'threat' we get here.
I got the white to help reject heat.  Never considered the parking lot light idea, though. Good thinking.
Bangorbob
« Reply #4 on: February 19, 2021, 07:15:42 pm »
I probably should not have specified a particular brand vent cover.  I am open to any and all covers.
Bangorbob
« Reply #5 on: February 20, 2021, 10:37:26 am »
Volkemon,   What is the brand name of the covers?   Also it looks like the bathroom vent cover may overlap the shower skylight.  Did you use the same cover for both?
Thanks, Bob
Bangorbob
« Reply #6 on: February 27, 2021, 11:28:28 am »
Update-A couple of pictures of installed vent covers.
« Reply #7 on: March 06, 2021, 01:51:29 pm »
Thanks, Bob
Sorry for the late reply.  Donc13 nailed it before.  ''Fan-Tastic Vent U1500WH Ultra Breeze Vent Cover - White''  is what the Amazon record says, $119.98 for two. November 2017.  They have held up well. The 'waffle' grid style seems to stop a lot more water than the 'slit' style. Florida issue.  :)(:
The rear cover does go over the sealant on the back skylight slightly, if I remember right.  The way the cover mounts, there is a ~1/4 gap to the roof, so the sealant layer isnt an issue.
YOURS LOOK GREAT!   2o2 2o2 2o2 (cheer)
Bangorbob
« Reply #8 on: March 07, 2021, 10:06:54 am »
Thanks.  While I was up there, I also changed the a/c cover.  It was shot.  Am currently working on a rain gutter extension on the drivers side by the awning.  I am making it myself.  I will be changing the flooring in the next month or so.  Going to use lifeproof silver oak.
« Reply #9 on: March 08, 2021, 07:07:17 am »
Same product and color I used. Mrs V is VERY happy with it.  If you go on Facebook, I have a few pictures there.   https://www.facebook.com/media/set/?set=a.860942294108982&type=3
Bangorbob
« Reply #10 on: March 08, 2021, 10:29:48 am »
Volkemon,  A little off the subject of vent covers, but what size carriage bolts did you use to replace gen/other bolts?  I didn't realize how close in color the sterling oak is to the carpet.   Gotta do 2 bedrooms in the sticks & bricks 1st-so the boss says.  Thanks to all for the great ideas and tips.
r/Bob
« Reply #11 on: March 08, 2021, 06:53:50 pm »
r/Bob
ooOOoooooh thats a good one.  I wanna say I used 3/8 x 4 inches.  The floor was ~ 2 3/4" thick I do believe. I put extras on the right side to mount underfloor stuff with later. I will go under tomorrow and double check.
Carpet was a no-go for Mrs V so none remains. Throw rugs dont count.  :lol
« Reply #12 on: March 09, 2021, 02:47:12 pm »
OK, the four holes formerly for the chair remained open on the bottom, and a depth check shows it 2 1/2 inches floor thickness.
My 2006 model 2350 floor appears to be 3/4 plywood, 1 1/2 inch foam, and 1/4 inch corrugated black plastic sheeting. (top to bottom)
I did use 3/8 x 4" carriage bolts for the right side, looks like similar for the LP Tank and genset mounting.
Happy Flooring!  :)(:
« Reply #13 on: March 09, 2021, 04:38:16 pm »
This is the PC floor sandwich.  I don't know material thicknesses.
« Reply #14 on: March 09, 2021, 05:21:26 pm »
I'd guess 2" steel tubing and insulation, 3/4" plywood floor....
