Propane/CO2 CCI Replacement
  • 3 Replies
  • 12905 Views
zolman
  • 109
  • PurchDate: 12/29/2021
  • ExtColor: white/gray/black
« on: January 30, 2021, 04:45:57 pm »
Recommendations appreciated for 2007 2551 - best replacement for CCI 7771 detector (2 wire).
I'm having trouble matching the CCI 7771 model with the correct Safe-T-Alert model.  I can only match the CCI 7770 and 7773 units.
Cropduster
  • 124
  • PurchDate: 05/2015
  • ModelYear: 2002
  • IntColor: Brown
  • ExtColor: Brown
Re: Propane/CO2 CCI Replacement
« Reply #1 on: January 30, 2021, 06:38:10 pm »
In our PC2100 I replaced the original alarm with a Safe-T-Alert model 30-442-P.  If fit without any modification being required.  YMMV.  A separate Kiddie CO detector is installed at the recommended 5' height.
« Last Edit: February 01, 2021, 03:46:19 pm by Cropduster »
« Reply #2 on: January 30, 2021, 07:37:52 pm »
According to my search, if it is a propane only detector, then Safe-T-Alert model 30-442-p is a direct replacement for the 7771.
If you want to upgrade to a dual CO & Propane detector, the model 35-742 Safe-T-Alert is a direct replacement for the 7771
This link is to a power point document about that
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.stadealer.com/uploads/1/8/4/1/18412059/rv_safety_alarm_information_for_technicians_07-162.pps&ved=2ahUKEwikgMLp9sTuAhULCTQIHQEOAHgQFjAAegQIARAB&usg=AOvVaw0WF7HJBWVkRHFiyimIjPZM
These 2 slides are the important ones...
« Last Edit: January 30, 2021, 07:45:26 pm by donc13 »
zolman
  • 109
« Reply #3 on: January 30, 2021, 10:55:28 pm »
Thank you for all the info.
Ordered recommended replacement today from www.newegg.com for $78
