Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Guest
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
Propane/CO2 CCI Replacement
« previous
next »
Pages: [
1
Go Down
zolman
109
Enjoy traveling with wife and 3 fur babies
NewUsed: Used
PurchDate: 12/29/2021
Model: 3100
ModelYear: 2013
IntColor: Cherry cabinets/grey vinyl furniture/white counters
ExtColor: white/gray/black
on:
January 30, 2021, 04:45:57 pm »
Recommendations appreciated for 2007 2551 - best replacement for CCI 7771 detector (2 wire).
I'm having trouble matching the CCI 7771 model with the correct Safe-T-Alert model. I can only match the CCI 7770 and 7773 units.
Cropduster
124
NewUsed: Used
PurchDate: 05/2015
Model: 2100
ModelYear: 2002
IntColor: Brown
ExtColor: Brown
Re: Propane/CO2 CCI Replacement
Reply #1 on:
January 30, 2021, 06:38:10 pm »
In our PC2100 I replaced the original alarm with a Safe-T-Alert model 30-442-P. If fit without any modification being required. YMMV. A separate Kiddie CO detector is installed at the recommended 5' height.
Last Edit: February 01, 2021, 03:46:19 pm by Cropduster
PurchDate: 03/2015
Model: 2551
ModelYear: 2015
IntColor: Nightscape/Hickory
ExtColor: White/Nightscape
Reply #2 on:
January 30, 2021, 07:37:52 pm »
According to my search, if it is a propane only detector, then Safe-T-Alert model 30-442-p is a direct replacement for the 7771.
If you want to upgrade to a dual CO & Propane detector, the model 35-742 Safe-T-Alert is a direct replacement for the 7771
This link is to a power point document about that
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.stadealer.com/uploads/1/8/4/1/18412059/rv_safety_alarm_information_for_technicians_07-162.pps&ved=2ahUKEwikgMLp9sTuAhULCTQIHQEOAHgQFjAAegQIARAB&usg=AOvVaw0WF7HJBWVkRHFiyimIjPZM
These 2 slides are the important ones...
Last Edit: January 30, 2021, 07:45:26 pm by donc13
zolman
109
NewUsed: Used
Model: 3100
ModelYear: 2013
Reply #3 on:
January 30, 2021, 10:55:28 pm »
Thank you for all the info.
Ordered recommended replacement today from
www.newegg.com
for $78
Pages: [
1
Go Up
« previous
next »
