Rear Differential
  • 8 Replies
  • 15295 Views
Rear Differential
« on: December 04, 2020, 08:26:48 pm »
I have a 2011 E450 and it's time to change the rear differential Fluid. Does anyone know where I can locate the information as to which Differential it has? Theres a couple possibilities and I don't see it on the differential. Is there a label somewhere or a secret decoder ring that might divulge the info?
Re: Rear Differential
« Reply #1 on: December 05, 2020, 06:08:59 am »
Try the door sticker?
https://www.blueovaltrucks.com/tech-articles/identify-your-ford-truck-axle-from-the-door-sticker/
Tag number on axle?
https://www.differentials.com/technical-help-2/differential-identification/
My Ford door sticker says I have a  '52' and that crosses to a Dana 70 HD   7400#   4.10 Ratio.      Found a couple other charts and they agreed FWIW.
But the PC sticker I have says I have a 7800# rear axle rating. I am not gonna lose any sleep over that, but imagine it will spike alarm from others.
« Reply #2 on: December 05, 2020, 08:49:19 am »
A dealer can lookup that information for you via the VIN number.  You can do it yourself via the VIN on the Ford parts website also (not an auto parts store).
« Reply #3 on: December 05, 2020, 10:53:48 am »
Volk, thanks, no tag on mine. I won’t lose sleep over having one or another. There are three options and two diff lube requirements and that’s where I want to get it right .
Don. Using the VIN, Your probably right, that’s the secret decoder ring when all else fails.
Thank you both!
« Reply #4 on: December 05, 2020, 01:52:43 pm »
Thank you both!
Did you not have a door sticker??   I have not even looked to see if I have a tag. Vin should work, dunno. My sources all said door sticker was the #1, then axle tag as a backup.
The sticker SHOULD be located in the drivers door jamb. Its a Ford factory sticker and should never be removed or defaced.
EDIT - Very Odd. Tried https://www.ford-trucks.com/forums/vindecoder.php  and the VIN for the PC shows as invalid. My other truck (a nissan!) works fine.   Tried https://driving-tests.org/vin-decoder/  and the PC VIN worked.  (WH)   No axle info, however.
EDIT2 - Evidently rear axle is not a VIN specified thing. I did not know that.
Vehicle Descriptor Section
 Characters four through eight represent the model, body type, restraint system, transmission type, and engine code. The ninth character is a security code that authenticates the VIN.
« Last Edit: December 05, 2020, 03:02:19 pm by Volkemon »
« Reply #5 on: December 05, 2020, 06:23:14 pm »
Volk, so I called quick lane (connected to ford dealership) they advised SAE 90 gear lube. It takes a little over a gallon.  I’m at 63,000 miles. Being I tow and it’s heavy as it is I look at it as preventative maintenance to change it out . I intended to do it at 60,000 miles but stuff keeps side tracking me.  Heck sometimes I walk out to the garage and then can’t remember what I went looking for.
« Reply #6 on: December 06, 2020, 11:44:57 am »
Great! Glad that is resolved.
 You might want to, I add a 'moly' type additive (Molybdenum disulfide) to gear oil. (GEAR oil, Not the engine oil)
 Less friction, and I believe it is beneficial.   Down side is that it changes the oil to black/very dark brown so when checked later it has a 'burnt' appearance and may cause alarm if checked by an unknowing party.
 I happen to use the Kimball Midwest version, but have used many other types.  :)(:
« Reply #7 on: December 06, 2020, 12:13:50 pm »
I use full synthetic 75/140 gear lube, superb substitute for straight 90 weight
« Reply #8 on: December 06, 2020, 09:52:11 pm »
Thanks guys, much appreciated. I use synthetic in my jeep already so I’ll prob go that route. I hadn’t planned on going straight old school 90. Not that it wouldn’t work just think synthetic or like Volk mentioned adding to the base.
