oof air not putting out cold air.
  • 3 Replies
  • 9615 Views
« on: March 16, 2011, 08:02:44 pm »
The roof air is not putting out any cold air. uThe fan runs and even the heat strip works, but no cold air. I checked the 110v circut breakers. Help.
bert
  • 6
  • PurchDate: Oct 2009
  • IntColor: Umber
  • ExtColor: classic umber
Re: oof air not putting out cold air.
« Reply #1 on: March 16, 2011, 08:21:31 pm »
so  glad to meet you at Lazydays.  I'm sorry I don't know anything about these things.  My husband said to check the compressor to see if it is running.
Bert and Eldora
  • 365
  • PurchDate: 09/2011
« Reply #2 on: March 16, 2011, 09:04:56 pm »
Tom:
I know this sounds silly, but have you checked the switch on the thermostat to make sure it is on "cool" setting.  I notice that sometimes the switch get stuck in neutral as it were.  If the compressor is kicking on( lower the temp switch its lowest setting) and you are still not getting cold air, you may have a leak and lost your freon.  Well, its not called freon anymore but it is environmentally safe chemicals.  You can have the system checked for leaks and recharged.  On my last motorhome I had my ac guy that works on my ac system at the office come to my house and work on the mh ac system.  It worked great after that and I never had to move my MH to get the work done.
David  heartshower
« Reply #3 on: March 16, 2011, 09:22:45 pm »
If the heat strip is on with the fan running you need to switch from heat to AC.  If that doesn't do it, it is probably shop time for a new thermostat.
L. G.
