Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Guest
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
oof air not putting out cold air.
« previous
next »
Pages: [
1
Go Down
on:
March 16, 2011, 08:02:44 pm »
The roof air is not putting out any cold air. uThe fan runs and even the heat strip works, but no cold air. I checked the 110v circut breakers. Help.
bert
6
PurchDate: Oct 2009
Model: 2400 Ford
ModelYear: 2010
IntColor: Umber
ExtColor: classic umber
Re: oof air not putting out cold air.
Reply #1 on:
March 16, 2011, 08:21:31 pm »
so glad to meet you at Lazydays. I'm sorry I don't know anything about these things. My husband said to check the compressor to see if it is running.
Bert and Eldora
mciai2000
365
PurchDate: 09/2011
Model: 2552
ModelYear: 2012
IntColor: grey
ExtColor: full body night shadow
Reply #2 on:
March 16, 2011, 09:04:56 pm »
Tom:
I know this sounds silly, but have you checked the switch on the thermostat to make sure it is on "cool" setting. I notice that sometimes the switch get stuck in neutral as it were. If the compressor is kicking on( lower the temp switch its lowest setting) and you are still not getting cold air, you may have a leak and lost your freon. Well, its not called freon anymore but it is environmentally safe chemicals. You can have the system checked for leaks and recharged. On my last motorhome I had my ac guy that works on my ac system at the office come to my house and work on the mh ac system. It worked great after that and I never had to move my MH to get the work done.
David
lghjr
306
OwnPC: No
NewUsed: Used
PurchDate: Used to own a 2700
Model: 2700
Reply #3 on:
March 16, 2011, 09:22:45 pm »
If the heat strip is on with the fan running you need to switch from heat to AC. If that doesn't do it, it is probably shop time for a new thermostat.
L. G.
Pages: [
1
Go Up
« previous
next »
