Dead battery
  • 48 Replies
  • 46742 Views
  • 559
Re: Dead battery
« Reply #15 on: April 27, 2020, 10:34:04 am »
I am the source of the electrical wiring diagram. This is what is posted: https://keelhauler.org/RV/2552ElectricalSystem.jpg
If there are any corrections that you are confident that need to be made, please post here.
The white switch questions result in Phoenix changing something from 2012 to now. If someone would show exactly how it now works please explain, without Trik_L-Start. Put a 12v digital readout in one of the dash sockets and tell me what the voltage does when the engine is off and you push the switch then let it return and exactly what you have to do to get it to stay at coach voltage when not holding it on.
I have seen several PC's not do anything when that switch was pushed since there was a problem with their chassis relay wiring.
jim.godfrey
  • 292
  • PurchDate: October 2019
  • ModelYear: 2020
Re: Dead battery
« Reply #16 on: April 27, 2020, 10:49:38 am »
John: Just took a quick look at your schematic. Looks like there might be something in the area of the latching relay that might be different from what I saw yesterday.
But before I say too much I want to get in there and remove the big reservoir tank so I can get a good look to be sure.
Will draw up a hand sketch of what I find.
Should have some time Wednesday or Saturday.
Take care,  Jim G.
Engineerlt
Re: Dead battery
« Reply #17 on: April 27, 2020, 01:02:27 pm »
Hello Jim, Mike H and Keelhauler
Jim you said "What I did was hold the rocker switch on just until I heard it the big relay click, then turned on the ignition (but not try to start) I could then release the switch and the contactor remained latched in until I turned off the ignition.". Jim and Mike H Can you check this? If you just get in the coach and turn the ignition key until the idot lights light up in the dash cluster, and check and see if the relay is closed.  I did it just a second ago by having my wife turn the ignition switch while I just held my hand on the relay. I believe you are going to find that the relay closes. i don't believe there is any latching relay in the circuit, its possible PC changed something but don't see why they would add it to the wiring when its not needed.
Jim I believe this relay closes to charge the house batteries while traveling. Some older RV's were not wired this way and the only way to get the batteries charged was either solar or to plug in/generator and use the converter. Instead of using the white switch on the dash you could simply turn the ignition switch to the position where the idot lights light and do the same thing as the switch.  The only down side is that you power up items like the ECM and other electrical components that are just using power which is defeating what you are trying to accomplish ( raising the chassis battery voltage using the house batteries). It looks like the wire size is about a 6AWG going to the relay on the load side.  This tells me that it isn't sufficient enough to carry much of a load from the starter, thats why there is a automatic reseting circuit breaker on the load side of the relay from the house batteries. If your chassis battery is weak, you will most benefit by holding the rocker switch to close the relay and wait. You need to give it some time for the house batteries to discharge and bring up the voltage of the chassis battery ( batteries are actually trying to equalize voltage between them).  That is why some people on here have installed a toggle switch, so they can simply flip the switch give it 5 minutes or so then start the engine. It should be noted that this wiring scheme only will work if the battery is low on charge, if the battery is sulfated and shorted across the plates it won't help, it will just start draining your house batteries.
Keelhauler I would like to say thank-you for posting these wiring diagrams on the forum. Great reference material! I am under the impression that the only latching relay is the one that operates the water pump which is located under the passenger side bed on the 2552. Is this correct?
Like I said it is wired this way on my 2017 2552. If yours is different I would be very interested to know why it has changed.
Lance
  • 437
Re: Dead battery
« Reply #18 on: April 27, 2020, 02:30:19 pm »
If there are any corrections that you are confident that need to be made, please post here..
Hi John----
Good to know that you were the source of the wiring diagram!  I really appreciate you taking time to develop it and make it available--especially since Phoenix doesn't give us one.  Shortly after getting my unit I printed a large copy and added it to my electrical file in my collection of manuals for the RV.
The initial differences that had jumped out at me between that diagram and my 2019 2552 likely just stem from some evolution in components and circuitry used by Phoenix.  They have changed converters, of course, and my Progressive Dynamics PD4560 (aside from being a 50-amp system) has some minor differences in both the 12-volt fused circuits and the 110-volt breaker circuits from your original.
Since I've had no real electrical problems to date, I haven't  attempted to follow all the Phoenix add-on wiring to the chassis in detail, but most of what I've looked at definitely matches.  As Lance mentioned, however, that set of normally closed contacts that you depict immediately adjacent to the battery that appear to open when the ignition turns on don't exist on my unit (at least electrically where you have them).  The chassis battery side of the charging relay is connected directly to my chassis battery positive by a single unbroken cable.
I don't know what other minor changes might have been made by Phoenix on a year-to-year basis.  Consequently I am not suggesting that you "correct" your wiring diagram--unfortunately there may not be one "correct" diagram that applies to even the last several years of just the 2552 model.   I certainly welcome and appreciate what you've given us to work from with that initial diagram.  It's the basis from which we can at least identify the minor changes that might exist on our units.
All the best,       Mike
  • 437
Re: Dead battery
« Reply #19 on: April 27, 2020, 04:10:48 pm »
OK,  Lance.  Since I was already working on a post to another message in this string when your above message hit---I'll just add a couple of comments to your thoughts.  To preface, I'm not the expert on this issue.  Several years training and work as an electronics technician (many, many years ago), give me a pretty good understanding of these type systems, but my comments are opinions only.
First, you're correct, the primary purpose of this relay is to provide a way to connect/disconnect the house batteries to the Ford 12-volt system to allow the alternator to charge them.  Older systems used isolator diode units to do this, but everything later transitioned to relays.  You're also correct that this is not a "latching" relay.  It is simply activated by the key switch--it's open (disconnecting the house batteries from the Ford circuit) when the key switch is off, and engages (connecting the house batteries to the Ford 12-volt system) when the switch is turned on
 What Phoenix did with the "white switch" (as I mentioned in an earlier post), is just provide a second way to engage the relay from the house batteries.  If the chassis battery is fairly dead, there won't be enough voltage to pull in the relay by turning on the key switch.  But you can activate the "white switch and feed 12 volts from the house batteries through that switch to the relay coil to pull in the relay, connecting the house and chassis batteries.  This effectively allows the house battery charging circuit to be used in reverse to flow current from hot house batteries into a dead (or low) Ford chassis battery.
You're right that you can't provide "cranking current" through it--the 40-amp circuit breaker in the relay circuit limits current to that amount--and you also can't overcome a chassis battery that is shorted or open internally, but a good hot house battery bank can provide a pretty good boost to the Ford system over a period of time.  Info in the (very limited) Phoenix Owner's Manual that I received in my package recommends activating the "white switch" and then waiting "about an hour" before cranking the Ford.  That amount of time would pretty much allow a dead but decent chassis battery to fully equalize with the house batteries--likely enough to start the Ford.
Lastly---the question of whether to hold in the (momentary) white switch, or exactly how to do it.  If the chassis battery is not too low (say barely cranking, but not enough to start), one might hold in the momentary switch for a while and get enough help in there from the house batteries to allow it to crank off.  However to follow Phoenix's suggestion to allow an hour---well, that's a long time to hold in a momentary switch.  For a really dead battery, probably the best bet with the momentary switch would be to hold it in long enough to let the house batteries get the chassis system voltage up to the point that the relay will hold in from the key switch feed--then just the key switch being on will keep the relay in.  You're right that that approach means that the other systems that come on with the key pull some of the power you're putting in from the house batteries, but probably won't pull enough to defeat the process.  That's where the option of the toggle-type switch recommended by John (Keelhauler) comes in.  The toggle switch eliminates having to hold in the momentary switch (and/or) then use the key switch for long periods.  The only concern that may come with that method is the possibility of the switch being left on or turned on when it shouldn't be--with any negatives that accrue from that.
Sorry that the "couple of comments" got more long-winded than intended (and some are repetitious), but as Jim said there's no charge for them.
Mike
  • 559
Re: Dead battery
« Reply #20 on: April 27, 2020, 05:04:44 pm »
I made a new sketch of charging relay and white switch. Right side or original diagram.
If it looks right, I'll change the electrical drawing.
So Coach batteries charge when vehicle ignition is on and engine is running.
Chassis battery charges when the white switch is in the on position.
« Last Edit: April 27, 2020, 05:07:21 pm by keelhauler »
  • 437
Re: Dead battery
« Reply #21 on: April 27, 2020, 05:28:56 pm »
Hi John,
I believe that, electrically, with this diagram you're on the money with the connectivity of my 2019 2552.  Can't speak for other years/models.
Of course, we've been calling this a wiring diagram when in fact it's a schematic--but at least for me a schematic is really what you need to understand the circuit or use to troubleshoot.
I admire your ability to quickly construct the diagram and get it posted--I have trouble even trying to post a picture sometimes.
Again, thanks for your help in filling a void for us that Phoenix hasn't yet managed to do.
All the best,        Mike
jim.godfrey
  • 292
  • ModelYear: 2020
Re: Dead battery
« Reply #22 on: April 27, 2020, 05:31:49 pm »
John: Thats likely what my rig looks like. I just never checked to see that the ignition would pull the relay in without being initiated with the white switch. Hence my erroneous reference to a latch relay.
Once the rain stops I'll get a closer look to confirm.
On my trickle start the yellow wire that is supposed to be tied to house battery is connected where I've drawn the blue circle below. No house  power there unless the relay is activated.
Now lets see if I can get this picture attached...
Re: Dead battery
« Reply #23 on: April 27, 2020, 07:38:37 pm »
After looking at LSL's website relative to the Trik-L-Start, it's designed to monitor both chassis and house batteries.  When the chassis battery gets low, current will be drawn from the house batteries (and or a solar array).  With the yellow wire for the house batteries located where you circled... It would not work.
In addition, the 'presumption' is that your house batteries are being kept charged by either being plugged into shore power or a solar array.   Your house batteries cannot really charge anything if they aren't fully charged themselves
As you know, the engine battery without something like the trk-l-start gets zero charge when the alternator is not running.   I was plugged into shore power for a couple of weeks at my son's house.  I had a small 75w inverter plugged into the chassis 12v plug.
Went to start engine.... Zip, Zilch, Nada.  A Trik-L-Start would have prevented that.   But not if the yellow wire is only connected to the alternator output/12v chassis battery plus terminal.
You need yours rewired.
Do
jim.godfrey
  • 292
  • ModelYear: 2020
Re: Dead battery
« Reply #24 on: April 27, 2020, 08:47:25 pm »
Yep, its next on the list.  ;)
Will probably get it done when I install the new radio. Need to pull some  power to it for the amp so if I I may grab it at the relay or possibly the cigarette lighter if it is wired for 30amp.
jim.godfrey
  • 292
  • ModelYear: 2020
Re: Dead battery
« Reply #25 on: April 29, 2020, 08:24:01 pm »
My bad.
Removed the reservoir to get  a better look today and found that although there is a yellow wire on the charge relay coil terminal, it is NOT the yellow wire from the Trik-L-Start.
Faith restored in Ed the guy that wired all out units!
There are three wires on the coil terminal of the relay, I now assume one is from the ignition. One from the white switch, and something else. Maybe to retract the step? It is a yellow wire, slightly larger gauge than the Trik-L-Start.
Sorry for assuming the worst PC.
Here's what it look like in there.
  • 437
Re: Dead battery
« Reply #26 on: April 29, 2020, 11:44:31 pm »
Jim, your wiring duplicates mine.
I'm sure that you're correct about the ignition and the white switch wires.   I didn't attempt to determine purpose of the third wire, but I suspect that your step retraction thought is a excellent candidate.
Mike
  • 559
Re: Dead battery
« Reply #27 on: April 30, 2020, 12:06:26 pm »
Jim.Godfrey
That's it, My sketch is wrong where it ties in, I'll correct the drawing.
Corrected System Schematic
« Last Edit: April 30, 2020, 12:38:25 pm by keelhauler »
jim.godfrey
  • 292
  • ModelYear: 2020
Re: Dead battery
« Reply #28 on: April 30, 2020, 01:14:19 pm »
That looks right to me John.
Re: Dead battery
« Reply #29 on: April 30, 2020, 02:00:21 pm »
There's actually about a 20 second delay between when the ignition goes on (or maybe engine start) and when the alternator output goes to the coach battery circuit.
I say this because while in storage, with all batteries disconnected, in order to start the generator via the chassis battery, I close the chassis battery knife switch (leaving coach batteries disconnected completely) then I start the engine and wait about 20 seconds before I have any power to prime or crank the generator.    Not sure about the interior lighting because I typically don't turn it on.  So there is some form of a time delay latch in there too.
Don
« Last Edit: April 30, 2020, 02:03:36 pm by donc13 »
