Screen door
  • 13601 Views
Janey
  • 112
  • PurchDate: 8/19/14
  • ExtColor: Cafe
Screen door
« on: October 10, 2019, 03:47:09 pm »
Has anyone replaced their screen door?    A dog shredded part of it.  Yes, I’m a bit cranky about it.
Janey
jimmer
  • 156
  • PurchDate: 5 / 2016
  • ExtColor: WHITE OVER BLUE
Re: Screen door
« Reply #1 on: October 10, 2019, 09:11:53 pm »
Hi Janey,  our  door suffered the same fate.  Brought it to  P.C. factory hoping to have the screen replaced.     They  said it was too far gone and had to be replaced.
They did a beautiful job, and quickly, as usual.      Better than the old one.      This was about 4 years ago, for about  $ 275.    Last year the latch broke, sent  for a replacement
from P.C.     No problems since.
Jim
Re: Screen door
« Reply #2 on: October 11, 2019, 08:50:40 am »
Hi Janey,
It sounds like someone else's dog ruined your screen door.  If that is the case, then.....   pyho
Depending on the location of the hole in the screen, there just might be enough extra material rolled up in the screen to simply cut-off and re-attach the leading vertical metal portion.  Carefully grab and pull out as much screen as possible to see if you have enough extra material to work with.
« Last Edit: October 11, 2019, 08:53:11 am by Ron Dittmer »
Janey
  • 112
  • ExtColor: Cafe
Re: Screen door
« Reply #3 on: October 11, 2019, 10:01:07 pm »
No!  It was my own devil dog - King Tucker.  We had a really great mobile rv tech do some work on our Moho today. He said there are two screws at the top and bottom. Just remove it - take it to a hard ware store and they can replace it.  He said it would be cheaper than what he would charge us. Well, we’ll have to check it out.
Janey (hoping for the best in Michigan)
Re: Screen door
« Reply #4 on: October 12, 2019, 07:43:48 am »
Be careful. That screen door is under tension. I'm not sure how the mechanism works. I remember an old post about it though.
Chuck1944
  • 12
  • PurchDate: 11/2014
  • IntColor: Sand
Re: Screen door
« Reply #5 on: October 12, 2019, 10:42:24 am »
We must have the same dog.  I have a 2015 Phoenix 2350 which my dog also went thru.  You have three types of repairs. 1) a stick on patch which will not work if the rip is near the frame; 2) buy a new screen door thru Liftco, 574-266-5551, cost back in 2017 was $250.00 plus freight; or purchase a new screen cut specifically for the door through Stoett Industries in Hicksville Ohio, cost approximately $60.00.
Option two takes approximately one hour and is very easy.  Option three also takes about one hour but can be frustrating if the screen unwinds while you install it. The you have to start over again.  Note that you may also need two sided tape which you can get through Stoett.
Good luck.
Engineerlt
Re: Screen door
« Reply #6 on: November 13, 2019, 03:44:05 pm »
I just finished changing out my screen in the door and snapped in a new latch. I got the screen from Stoett Industries. Penny Battershell got me what I needed. I had to send her the length of the housing. The screen was $57.51 and the latch was $11.25 plus $22.00 for shipping. The installation was straight forward and pretty easy. She sent me instructions on how to accomplish the install. I had to purchase some mounting tape/adhesive 3M VHB tape part #4910 1/2 inch wide, sticky stuff. The hardest part was cleaning off the old tape/adhesive. Here are a couple pictures.  I also have included the instructions from Stoett.
Replacing a Screen
 1. Remove the retractable screen from the door. There will be two screws at the top and bottom of the housing to remove. One of the screws will require the plastic screw cap to be removed. To remove the plastic cap, use a thin metal blade around the outside edge to gradually pry it out.
 2. Once removed from the door, set the retractable screen cartridge on a flat table. The housing should be placed closest to you, and the pull bar facing away from you. This positions the spring end on the right hand side.
 3. Remove the end caps from the housing, starting with the right side housing cap. WARNING: Hold this cap securely when removing it as the spring is under tension. Remove the 2 mounting screws that attach the housing cap to the aluminum housing. Hold the housing cap securely with one hand and the aluminum housing with the other and remove the housing cap. The spring tension will release when you remove the end cap. No damage to the mechanism will occur by doing this. (Note: Make sure not to lose the small plastic insert).
 4. Remove the opposite housing end cap and remove the roll tube and screen from the housing.
 5. On a flat clean area, roll the screen out off the roll tube. Remove the screen from the roll tube by peeling the screen from the tube. The screen is attached to the roll tube by double stick tape.
 6. Once the screen is removed from the roll tube, remove the screen from the pull bar by removing the pull bar end caps and sliding the v-clipped screen from the aluminum pull bar extrusion.
7. Slide the new replacement screen back into the pull bar and reattach the pull bar end caps. Roll the screen back up onto the roll tube. Use the groove on the roll tube as a guide to ensure the edge of the screen is properly inline to the roll tube. Ensure the screen is secured onto the double stick tape. (New tape may need to be added). Ensure the screen does not hang over either edge of the roll tube.
 8. Slide the housing on the roll tube, with the roll tube and spring extending past the housing. Telescope the screen a little so the flat spring end is protruding past the screen. (kind of like pushing in the middle of a rolled up newspaper) This will keep the screen back and out of the way when winding the spring.
 9. Place the end cap that matches the spring end onto the flat pin. With your finger on the protruding part of the end cap, wind the cap up 15 turns in a clockwise direction and push it into the housing (wind the cap 15 times if a hydraulic slow close or geared slow close device is to be use or 17 turns if a hydraulic slow close device is used with Pet Mesh or Solar Screen). WARNING: Securely hold the housing cap while winding the spring to ensure it does not release. (this can be tricky the first time; however, once you’ve done it once, you will find it is fairly easy)
 10. Insert the screws into the housing end cap on the spring side.
 11. Carefully move to the opposite side and insert the housing cap on the pin (or slow close) side. Attach the screws into the housing cap.
 Final Inspection
1. Pull the screen out a few times to ensure there is no vibration and the screen operates smoothly.
 2. The screen edges should be even from each side. Be careful not to damage the screen at the housing cap while pulling it out for a “dry run”.
 3. Your replaced screen should now be ready to be reattached to the home.
