2008 Model 2400 monitor panel circuit board
  • 1 Replies
  • 8248 Views
ROF
« on: October 19, 2018, 05:17:48 pm »
I purchased a 2008 Phoenix Cruiser Model 2400 several months ago. The gray, black, fresh water and voltage monitor panel did not register correctly, even after replacing the tank sensors. I needed a new circuit panel for the monitor system that is mounted on the cook top vent hood. Phoenix Cruiser was not much help in locating a new circuit board. I called Ventline/Dexter, the hood manufacturer (574-848-4491). They were great. I gave them the number on the back of the circuit board (L5096-54) and they had a new one made for $65.00. Now it works!
Re: 2008 Model 2400 monitor panel circuit board
« Reply #1 on: October 19, 2018, 05:42:32 pm »
I think our 2007 has the exact same monitor panel, though it has always worked well.  It is good to know that if something fails, there is a replacement circuit board available.
Thanks for sharing that.
I added a volt meter, clock, temperature combination unit into the panel.  I almost always set it to display the battery voltage.  But the other data is easily displayed when they become more important.  You can read about the project by CLICKING HERE
You might also find THIS interesting given you have the same microwave and installation.
« Last Edit: October 19, 2018, 05:47:15 pm by Ron Dittmer »
