Trailer behind a 2006 model 2350
  • 11323 Views
« on: June 21, 2018, 07:19:15 pm »
Looking at getting a used trailer tomorrow, one of these -
http://chariotmanufacturing.com/?page_id=279
5K GTW, 1200# empty, 90(!) # tongue weight, Dual torsion axles... looks like its perfect. Going behind a 2006 Model 2350.
Advice? Opinion?
Interior Length   13' 8"
Inside Width   7' 6"
Inside Height   6' 3"
Outside Length   17' 9"
Outside Width   8'
Out Side Height   7' 10"
Base Weight   1250
Tongue Weight   90 Lbs
Hitch Ball   2"
Ball Height   17"
Axle GVWR (all axles torflex)   3500 ea.
Number of Axles   2
Body Load Capacity   3650
This is a later model one, minor trim differences.
 tymote
Re: Trailer behind a 2006 model 2350
« Reply #1 on: June 21, 2018, 07:33:30 pm »
Hi Volkemon,
I would consider the following.
- Make sure your PC has a 5000 pound hitch in good condition.  They like to rust badly and weaken from it.  Phoenix used to install a 3500 pound hitch.  I don't know when they switched from the 3500 pound hitch to the 5000 pound hitch.
- Consider a heavy duty rear stabilizer bar.  Being a 2006 E350, you have NO rear stabilizer bar unless installed by a previous owner.
- Consider installing a rear trac bar to prevent the "tail wagging the dog" effect.  Trailers like to thrash side-to-side, the back-end of a short motor home with a short wheel base and long rear over-hang.  The location and position of a half full fresh water tank in a 2006 2350, the water sloshing side-to-side amplifies the problem.
BTW:  Nice choice for a trailer.  2o2  What is your plan with it?
« Last Edit: June 21, 2018, 07:38:48 pm by Ron Dittmer »
JJCruiser
  • 131
  • PurchDate: 10/2018
  • IntColor: Nightscape
« Reply #2 on: June 21, 2018, 10:47:52 pm »
I agree with Ron.  I currently have a 2007 2350.  Towing just a Honda CRV changed the handling significantly when compared to towing nothing at all.  I had to add the rear sway bar and trac bar, they made a big difference when towing.
That is a sharp trailer!  It will look good behind a PC.
JJ
« Reply #3 on: June 22, 2018, 10:21:23 am »
That’s a sharp looking trailer, you looking at hauling motors (bikes)?
« Reply #4 on: June 24, 2018, 09:39:46 am »
Hi Volkemon,
I knew 90% of what you would say from studying your other posts...and its on the plan.  :-D  Future plans below.
JJ
It looks AWESOME behind the PC. Painted to match would look like a factory package.
Thanks!
I will be posting pics, but too busy working. Great little trailer. Towed like a dram empty  We had a headwind 100 miles home, and it almost bobbed around a bit it was so light. Never felt it behind the wheel, even over rough bumps. LOVE a tandem axle.
Our hitch is a 5K or 6K with equalizer. Structurally very sound, but I might add a little bracing. Lucky for me, this coach has no rust to speak of.  Plan is to get a weight distributing hitch to use those axles out back, they are 3K each. :)
It (The trailer)  came with a LARGE roof unit installed in the forward 14x14 vent hole, which had the roof collapsed.  :beg  Current owner was lacking skills to repair, so I now own it. :)  Roof unit is pulled, and I am making up roof struts today.
13 foot inside length, 7 foot width.   6'3" inside height.  LOVE IT.  The rear ~8 feet will be cargo hauling, and the front looking to be a camp kitchen/light storage area.
Will be perfect to haul our golf cart, my motorcycle, or ?? we decide on later.
Pics are from the craigslist ad, the inside is empty except for a roof brace right now.
« Reply #5 on: June 26, 2018, 04:04:09 pm »
Finally got the 'bringing it home' pic off Mrs V's phone.  ;)
« Reply #6 on: June 26, 2018, 08:12:42 pm »
2o2
