Exterior Paint
  • 26 Replies
  • 36966 Views
JOHN
  • 50
  • PurchDate: pickup 10/2016
  • ModelYear: 2016 - 2351 Ford
  • IntColor: Nightscape
  • ExtColor: Standard Paint
Exterior Paint
« on: July 15, 2016, 11:47:26 am »
I am picking out the exterior paint for my PC and I have three options:
1.  Full Body Paint
2.  Lower Body Paint
3.  Standard Paint (does not include 1 or 2).
I understand that I will need to maintain the exterior surface.  Many from the forum say to keep the surface relatively clean and wax twice a year.
I would appreciate your comments (regardless of your preference of the above 3), if the exterior is properly maintained in each of the above 3 for a like use and storage, would the exterior (I guess appearance of the exterior) age differently?
Thanks - John
Re: Exterior Paint
« Reply #1 on: July 15, 2016, 05:29:10 pm »
John, You ask a very good question.
If you look at older PCs for sale on the internet, the ones not painted having raw plastic parts like the side mirrors, stove vent, things like that tend to "fade yellow" fiercely from the sun.  Then the rig does not show as well.
Also consider that unpainted fiberglass becomes hard to look good over time.  No matter how determined you are, the surface will get chalky and then harder and harder to keep looking as white as before, staining quickly from rain streaks too.
If plain old white is your color, I would consider having the entire rig painted white.  The painted surface will be much easier to maintain, the white color would reflect the heat of the sun best, and it resists fading most.  The question to ask is....how are the dark colored full body paint jobs holding up to the sun?  Our 9 year old rig still looks great, but is stored indoors which is not a fair evaluation.
« Last Edit: July 15, 2016, 05:39:01 pm by ron.dittmer »
Re: Exterior Paint
« Reply #2 on: July 16, 2016, 11:59:13 am »
I don't agree at all.
I'm on my third all natural Gelcoat white RV.
The first one was 11 years old, all the gelcoat still looked brand new. But I did wax with a good gel coat wax twice a year. It was outside uncovered all the time.
I do agree that some parts discolor. The mirrors are painted and did discolor but are easy to repaint. Some of the small fiberglass doors discolor.
My second RV was a PC, all white 6 years old, still looked new.
Present RV is 4 years old, still looks new.
I can post pictures after 11 years and the PC at 6 years to prove what I say.
The piece that is hardest to maintain is the front cap.
The key is maintenance. If it gets away from you you can switch to a cleaner wax to get the shine back.
JOHN
  • 50
Re: Exterior Paint
« Reply #3 on: July 16, 2016, 12:38:45 pm »
John (Keelhauler) - thank you for your response, currently with a white PC (is that the "Standard Paint") and already having two previous (all stored outside and plenty of sun, including most winters in Mexico).  I am not surprised yours have stayed in good condition.
I have been corresponding with Earl Robbins with PC and this was his written response:
"The white color on the Ford Hood is paint from Ford. So it will weather just like your car or truck.
The white on the rest of the coach is Gelcoat fiberglass.  We use a better quality of gelcoat than most RVs.
However the rear and front cap is different than the sidewalls. They will fade over time and not at the same rate.
If you get the full body paint then it is all paint and 2 coats of clear and hand sanded and buffed.
This paint is like your car or truck and should with reasonable care last for the life of the coach."
I will see if I can get Earl to provide more on the "Standard Paint".
Thanks John and Ron with your responses,
Re: Exterior Paint
« Reply #4 on: July 16, 2016, 12:51:03 pm »
I agree with Earl, but the Ford paint is as good as any paint, easy to maintain.
The front cap is really the only piece that requires extra care but it does not seem like it is worth the extra cost of painting the entire RV just to make the cap look perfect.
Re: Exterior Paint
« Reply #5 on: July 16, 2016, 02:31:38 pm »
Full body paint cost 6% of the 2350 cost without options. Also think about tradein or resale value. Try Kelly blue book or nada and see the difference on a 5 year old motorhome. Subtract that number from the cost of full body. Now think about which looks best to you. Even if you like a single color, like white, you should ask Earl about the cost of just one color.
I have had motorhomes both ways and I think the full body is easier to keep clean looking. When I was a young man I washed and waxed the motorhome every month. Boy did it ever shine. Now I use gel coat wash and wax. I can be really lazy some times. Any way this hobby is about having fun not having to work. I can stay home and work.
 What you want is what counts. ;)
JOHN
  • 50
Re: Exterior Paint
« Reply #6 on: July 16, 2016, 04:35:20 pm »
Hi John,
Seems that if there might be a problem, then it would be the front cap.  I meant to ask you do you have the Diamond Shield anywhere?
I will ask Earl if I can just give the front cap special (paint treatment).  Then see if I can just go with the "Phoenix Cruiser" graphic on the four sides.
Thanks for your comments,
Bob Mahon
  • 547
  • PurchDate: 6/2011
  • IntColor: Tan/Gray/Cherry
  • ExtColor: Lower Slate Gray
Re: Exterior Paint
« Reply #7 on: July 16, 2016, 10:31:27 pm »
All 3 of my PCz had lower or no paint and all did OK.
Caution: make sure you don't get the Phoenix Cruiser decals on the cap. They will start to peel and when you remove them there will be a 'ghost' of the decal left, which looks terrible.
Re: Exterior Paint
« Reply #8 on: July 17, 2016, 01:22:46 am »
My earlier reply about long term reliability issues on a gel coat fiberglass rig is based on THIS motor home we owned for 24 years.  19 of the 24 years, the rig was stored indoors.  The pictures were taken in year 24 when selling the rig.  Pictures don't reveal the condition of the fiberglass, nor how quickly it would streak.  My experience is not with a PC.  Apparently all gelcoat fiberglass rigs are NOT the same.
« Last Edit: July 17, 2016, 01:35:44 am by ron.dittmer »
Syd and Margo
  • 91
  • PurchDate: 9/11
  • IntColor: Sunlit
Re: Exterior Paint
« Reply #9 on: July 19, 2016, 02:16:22 pm »
Go with full body paint.
When I wash my unit it is like washing a new car.  It looks so good.  I had enough gelcoat with the boats we have owned.
Full body paint makes the unit look up to date with other units.
Syd
Bruce
Re: Exterior Paint
« Reply #10 on: July 19, 2016, 06:19:53 pm »
I’m now in the group of PC owners that would recommend full-body paint because of the following brief history with ours.
Our 3-yesr old 2552 has lower body paint.  I’m almost obsessive in keeping it clean and protected from UV as it is always parked outside (summer it’s usually in the generally cool, foggy Monterey bay climate, winter it’s in sunny Palm Desert, CA)
My experience is that the painted surface needs much less attention to keep it looking like new.  The painted surface usually just needs a light wipe-down, while the non-painted surfaces needs more effort to remove accumulated dirt.  The gel coat seems to attract more grime.
The whole unit gets a complete wash and wax three or four times a year.
We recently needed to temporarily store the coach in a lot surrounded by evergreen trees and next to a metal fabrication shop for three weeks.  As I cleaned the coach I was horrified to see many small stains (most about 1/8" to 1/4" size) all over the unpainted gel coat on the driver’s side that I’ve not been able to remove.  No stains can be seen in the adjacent painted surface.
Rather than hijack this tread toward stain removal questions I plan to start a new thread on that subject.
--Bruce
« Last Edit: July 19, 2016, 06:47:28 pm by Bruce and Sharon »
garmp
  • 354
  • PurchDate: 3/20
  • ModelYear: 2020 2351D
  • IntColor: Greystone
Re: Exterior Paint
« Reply #11 on: August 10, 2016, 05:43:30 pm »
OK, a new guy here. Full body paint, lower body paint? What's this? Is it the base color and then all the swirls and or swashes are added?
What if I don't want the swirls nor swashes, or at least most of them?
We are thinking about a phoenix cruiser and plan to visit their facility this fall and negotiate, and would like to have some knowledge of what I would be talking about.
A nice color or even white with a simple swash and no name on the nose cap would be ideal. Are these points negotiable or even an option?
Thanks
Re: Exterior Paint
« Reply #12 on: August 10, 2016, 06:08:53 pm »
That is the great thing about Phoenix Cruiser.  You can negotiate with them on anything.  They will do their best to please you.  If they can't do it they will tell you.
We met a PC owner recently and they wanted full body paint without any swirls or swashes and that's what they got.  It also did not have any name on the cap.  So don't be afraid to ask.
Bruce
Re: Exterior Paint
« Reply #13 on: August 10, 2016, 06:43:26 pm »
I'll try to answer the full body vs lower body paint question.  Without any paint the entire exterior of the coach is the white gel coat that you can see in the current photos shown in the 2100 inventory section of the main Phoenix Cruiser page--the one that shows the unit at various stages of production where no paint or decals have been applied.
With half body paint, the very lowest parts of the exterior are painted with normal auto body paint and then decals are added for the swirls. You can see this in many of the other sections of the PC site, such as in colors.
With full body paint, the entire exterior of the coach has auto body paint applied so you see none of the white gel coat.
--Bruce
Bob Mahon
  • 547
  • PurchDate: 6/2011
Re: Exterior Paint
« Reply #14 on: August 10, 2016, 10:15:46 pm »
The fewer 'decals' the more you'll be pleased. They'll eventually peel or crack and look like hell.
As for me, if Phoenix wants to put their ID on the rear to advertise, I'd have a decision to make.
If I were to buy another new PC, I'd have none, unless it was all clear-coated.
Full body paint is nice, though.
