Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Guest
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
Passenger Seat
« previous
next »
Pages: [
1
Go Down
Passenger Seat
monacoman
10
NewUsed: Used
PurchDate: March, 2014
Model: 2400 Ford
ModelYear: 2009
IntColor: Beige
ExtColor: Brown
Passenger Seat
on:
September 15, 2014, 10:32:16 am »
Front passenger seat won't rotate. Any suggestions? 2009 2400.
1165
PurchDate: 10/17/11
Model: 2551
ModelYear: 2012
IntColor: Cherry
ExtColor: Classic Umber
Re: Passenger Seat
Reply #1 on:
September 15, 2014, 01:29:14 pm »
What happens when you pull the release handle toward you (when I am doing it from behind the seat the release is under the seat on the left)? When I pull on ours I can hear a spring working to release the stationary mode and allow me to swivel the chair. I also make sure the seat is all the way forward in the cab so that it doesn't hit the door when I turn it.
Sue
Last Edit: September 15, 2014, 01:34:42 pm by Barry-Sue
Current 2012 2551 w/Slide
monacoman
10
NewUsed: Used
Model: 2400 Ford
ModelYear: 2009
IntColor: Beige
ExtColor: Brown
Re: Passenger Seat
Reply #2 on:
September 15, 2014, 07:04:42 pm »
Thanks, Sue. When I pull the lever I, also, hear the spring, but the chair does not move.
1165
PurchDate: 10/17/11
Model: 2551
ModelYear: 2012
IntColor: Cherry
Re: Passenger Seat
Reply #3 on:
September 15, 2014, 08:13:02 pm »
Barry and I went out and took a picture of how ours works. (login to see the picture) When you pull the lever toward you a locking tab is released from a slot, at that point I hold it in the released position and then can turn the chair in either direction.
When you pull on your handle can you see the tab being pulled away from the slot as shown in the picture? If it is not then you will not beable to turn your chair. If you click on the picutre you can see it in greater detail.
If the locking tab is being released from its slot and it still doesn't turn I wonder if a bearing(s) is out of place or rusted out.
Last Edit: September 15, 2014, 08:35:02 pm by Barry-Sue
monacoman
10
NewUsed: Used
Model: 2400 Ford
ModelYear: 2009
IntColor: Beige
ExtColor: Brown
Re: Passenger Seat
Reply #4 on:
September 15, 2014, 09:39:26 pm »
Thanks, guys. Mine works as you describe, but just won't turn. Next stop: remove seat.
1165
PurchDate: 10/17/11
Model: 2551
ModelYear: 2012
IntColor: Cherry
Re: Passenger Seat
Reply #5 on:
September 15, 2014, 10:30:23 pm »
Let us know what you find!
Pages: [
1
Go Up
« previous
next »
