Floor Repair
  • 25206 Views
Floor Repair
« on: April 09, 2012, 01:39:28 pm »
Another tip we picked up at the factory.  If you happen to have to fix a small gouge, scratch, gash or maybe just a big hole in your floor use "SEAMFIL".  The two colors that you will need are 904 (TAN) and 941 (Almond). As seen here on amazon http://www.amazon.com/Almond-Seam-Fil-1-Oz-Tube/dp/B0006G84W4/ref=sr_1_4?ie=UTF8&qid=1333992351&sr=8-4.  You mix them together to get the color you need for the area you have to fix, apply, let setup and only you will know where that repair is.  I mixed the two colors together with a toothpick, applied a small dab and then ran a straight edge across the top to smooth it out.  It looks great if you can find where you repaired it!
Re: Floor Repair
« Reply #1 on: April 09, 2012, 07:32:41 pm »
What a great tip, I was wondering what to do about the small puncture in my floor.
thanks, Bob A
Re: Floor Repair
« Reply #2 on: April 09, 2012, 07:34:08 pm »
Bob, did you mark it helpful? I did. tymote
Re: Floor Repair
« Reply #3 on: April 09, 2012, 08:36:09 pm »
Yes I did
Re: Floor Repair
« Reply #4 on: April 10, 2012, 07:56:20 am »
I marked it helpful too.  Thanks Barry-Sue
