HELP! Where is themostat for water heater?
  • 11236 Views
Bbutler455
  • 9
  • Nancy - our retro-modern pre-retirement adventure
  • PurchDate: 03/2012
  • ModelYear: 2002 Phoenix Cruiser 2550 with bedroom slideout
  • IntColor: Jade
  • ExtColor: Cream with Jade accents
« on: March 24, 2012, 10:48:31 am »
We are on our maiden voyage with our new (used) PC 2550.  It has the atwood LP gas heater with the remote spark ignition.  The pilot lights, and the heater kicks on, but it doesn't stay on long.  Result... no hot water.  The manual doesn't show a themostat for the remote spark model.  How do you turn the temperature up... or is there something else I need to do?  I am sure this is a "stupid question" but Mary Lou will not be happy without hot water.  HELP!
Brock and Mary Lou
bigbadjc
  • PurchDate: February 2010
Re: HELP! Where is themostat for water heater?
« Reply #1 on: March 24, 2012, 11:35:07 am »
After reading your post, I googled Atwood temperature adjustments.  It turns out that most of the Atwoods apparently use a non adjustable 140 degree thermostat.  One article I read says these are prone to failure with age.  Atwood makes a replacement adjustable thermostat for about $35 or so.  You might want to ask your RV mechanic about this.
Jerry
Bbutler455
  • 9
  • IntColor: Jade
« Reply #2 on: March 24, 2012, 01:06:30 pm »
Jerry
Thanks Jerry,
So perhaps I am not a complete idiot.  It is a mechanical failure...  That's my story and I am sticking to it.
Brock and Mary Lou
lmichael
  • PurchDate: May 15, 2012
  • IntColor: Sterling
« Reply #3 on: March 24, 2012, 06:37:38 pm »
When you flip the switch by the sink to electric (when you have hook-ups of course), does your water get hot?  When you flip the propane switch, are you sure your propane valve on the tank is open?  If your refrigerator works when you have it on propane, then that's not your problem.  Could also be a blockage in your propane line at the water heater.  Spiders like these areas.
