infrared heaters
  • 9765 Views
infrared heaters
« on: November 07, 2011, 11:42:37 am »
we have a park model trailer we are not in but want to keep the place at a reasonable temp. been looking at infrared heaters, they say the use little electric. any one use something like this?
Re: infrared heaters
« Reply #1 on: November 07, 2011, 12:58:24 pm »
Infrared heaters only heat you not the air. If you are looking to keep things, like water, from freezing, they do not work. We use a small cube heater set on the lowest setting to keep the pipes from freezing. It doesn't seem to add much to the electric bill that I can tell.
« Reply #2 on: November 07, 2011, 09:36:44 pm »
we purchased a Duraflame, infared heater.  I guess i should have added Quartz Infared, From there web site:
What is quartz infra-red heat?
Quartz infra-red heat is safe, economical heat that evenly distributes warmth throughout your room.  Room air intake passes through the high efficiency lifetime filter that removes dust and dirt before entering the heater. A high velocity, whisper quiet fan, circulates air through the heater at 2 meters per second. The air then enters the Heat Chamber where it passes over 2 bent sheets of copper that are heated by 6 PowerHeat infra quartz heater elements.  Heat from the copper combines with the humidity in the room to provide soft, moist, heat.
