Sani-con,
  • 7902 Views
Sani-con,
« on: September 20, 2011, 01:48:17 pm »
I know we talked about this and I did look for the post. What size is the hose for the sani-con. Twice now my has plugged up. OK, OK after all the smarty remarks     roflol   has anyone else had this problem. I tried prune juice!   roflol   I am going to make a flusher. Both directions, towards the sani-con and the pump. I think my hose expanded to 40' today, scary.
Re: Sani-con,
« Reply #1 on: September 21, 2011, 06:09:07 pm »
someone posted a picture and explanation. it showed a valve of sorts in the storage area. i think it was some kind of relief/back wash valve,
 DOES ANYONE REMEMBER WHERE ON OUR FORUM IT IS??????????
Re: Sani-con,
« Reply #2 on: September 22, 2011, 12:45:15 pm »
Billy
I don't know who made the post. I have copied his idea. A clear tube is added to the discharge hose so you can see clear water as you flush. The valve lets air in to clear the discharge hose when complete, and a place for the discharge hose end cap.
 I'll send a picture. I hope.
George
Re: Sani-con,
« Reply #3 on: September 22, 2011, 01:38:51 pm »
Thanks George, it helps a lot. I'm going to consider something that will "flush" both directions. My stinky slinky has plugged up twice. Probably my fault, I should try and straighten out the hose a little better when using. But I do appreciate the photo.
