Power side view mirrors, 2016 E450
  • 7 Replies
  • 1389 Views
Camperfan
  • 17
  • PurchDate: 04/26
  • Model: 2351
« on: July 14, 2026, 07:31:25 pm »
Question for others who may have a 2016 e450 cutaway:
Are the lower convex mirror panels in the side view mirrors, remote power operated?
I ask because I have two switches on the driver side door frame. One is a round 3 position switch that selects the right or left flat panel of each side view mirror, and allows it to be adjusted.
Right above that round 3 position switch is a 2 position rocker switch which does nothing. I believe that rocker switch in opposite position transfers power which allows the lower convex panels to be adjusted. Mine doesn’t. But I can press on the convex mirrors with my fingers and adjust them.
So, I do t know if the lower panels are power adjusted or not. If so, mine do not work.
Anybody have the same setup? How does yours function?
  • 5714
Re: Power side view mirrors, 2016 E450
« Reply #1 on: July 15, 2026, 01:57:40 pm »
Without seeing a picture of your power mirror control panel, every one I have seen including the one in our 2007 model year, the rocker switch you describe, is for heating the mirrors for when ice forms on them.  Make sure the switch is turned "OFF" unless you are de-icing.
This is something everyone should check....
With your engine off and ignition key in-hand, test to determine if your power mirrors still operate.  If they do, then you want to MAKE SURE your heated mirror switch is in the "OFF" position, or your chassis battery will drain much more quickly.
« Last Edit: July 15, 2026, 02:37:49 pm by Ron Dittmer »
Camperfan
  • 17
  • PurchDate: 04/26
  • Model: 2351
« Reply #2 on: July 15, 2026, 03:12:23 pm »
Hmmm that is good for thought Ron. I wasn’t aware that I had heated mirrors. Is your convex mirrors power adjust?
  • 5714
« Reply #3 on: July 15, 2026, 04:50:50 pm »
Our 2007 mirrors are singles with a small stick-on extra convex mirror, not dual mirrors like the later PCs have, so I wouldn't know.
My own logic thinks your convex mirrors are stationary.  You can check yourself.  Push on an edge of the main flat mirror to make it move with micro-clicking.  Doing so will NOT damage it.  Then try doing the same with the lower convex mirror.  If it doesn't move with equivalent force, then it doesn't adjust.
Camperfan
  • 17
  • PurchDate: 04/26
  • Model: 2351
« Reply #4 on: July 15, 2026, 06:25:26 pm »
Exactly what I thought Ron.
From day one when I bought it the convex mirrors only moved manually and they didn’t have the same ratcheting feel that power adjust mirrors have when you move those with force.
I bet that rocker switch is for heat. Although this isn’t the weather for checking, someday I will be at the coast and will have forged/frosted  up mirrors and can confirm for sure!
LRUCH
  • 220
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • IntColor: Maple
  • ExtColor: White/Sage
« Reply #5 on: July 15, 2026, 10:45:59 pm »
Agreed, the round knob is for moving the upper mirror. Twist it to the left or right dot position to select a mirror, with center turning it off.
The rectangle switch will heat the upper mirrors in the up position and off when down. (I've seen a few models with no red dot and I suspect it just wore off, but not sure.)
The convex mirrors are mostly manual.
Larry
Larry
Camperfan
  • 17
  • PurchDate: 04/26
  • Model: 2351
« Reply #6 on: July 26, 2026, 01:57:26 pm »
Thank you Gentlemen! I was able to go to my PC last weekend and it is indeed a heated mirror switch. I turned it off LOL.
I could tell immediately upon starting the engine that the flat main mirror panels were warming up. Moved the rocker switch and felt again later that the panels were cooled. Back on, warming up, then back off for sitting.
Regards Ron
LRUCH
  • 220
  • Model: 2900
  • IntColor: Maple
« Reply #7 on: July 26, 2026, 09:32:33 pm »
You're quite welcome. Glad to help.
You're right in that they warm up quick. I've sat parked for days in winter Illinois in single digits and ended up with a coating of ice on my mirrors from a sleet storm.  But, with the engine running while I packed away the power cord and raised the jacks, the heat cleared them by the time I was ready to roll.
The folks who recognize these mirrors, are usually owners of a pair, or jealous of them. LOL
Larry
Larry
