Camping in below freezing weather
  • 1 Replies
  • 5970 Views
JJCruiser
  • 131
  • PurchDate: 10/2018
  • IntColor: Nightscape
« on: November 02, 2025, 10:58:47 am »
When my wife and I go camping in below freezing temperatures, we would be concerned about the freshwater tank and associated plumbing freezing.  Not so much anymore.  A couple of weeks ago I removed the plywood under the corner mattress on our PC2351 to install new wiring for a thermostat for the propane furnace.  I did this due to adding a new quieter 15k BTU Houghton AC removing the Dometic which has an integrated controller for the furnace.  In doing so I saw one of the openings for the flexible ducting on the propane furnace was open.  At first I thought it was odd but after a couple of seconds to think about it I realized that it was to keep the freshwater tank from freezing.  In testing the new thermostat, there is significant air that flows through that opening (much less I am sure when the plywood is in place).  It appears to be a very easy and effective way to keep the tank and plumbing from freezing.  Typically when we camp in cold weather and have hook-ups, to save propane we will use a small ceramic heater which does a great job keeping the interior warm.  But when it gets below freezing, we will make a point to use the propane furnace.
By the way, our first impression of the Houghton AC is very good.  The improved sound levels match what they advertised and is a noticeable improvement to the Dometic.  The Houghton has 15k BTU vs the 13.5k BTU which will hopefully give us more cooling on the very hot days. This unit also has a heat pump for when you want to quickly take the chill out of the RV on a cool (not cold) morning.  If anyone wants our low hour Dometic AC and thermostat, let me know as I will give you a great deal.  They work like new, but too loud for us.
JJ
zolman
  • 109
  • PurchDate: 12/29/2021
  • ExtColor: white/gray/black
Re: Camping in below freezing weather
« Reply #1 on: November 06, 2025, 02:06:02 pm »
Thanks JJCruiser. Great information!
