Fabric on the slide out ceiling
  • 15500 Views
Amsoilman
  • 71
  • PurchDate: 2024
  • IntColor: Grey
  • ExtColor: White Grey
« on: June 17, 2025, 07:57:46 am »
I have some sagging in the carpet like material. No stains to indicate water   What have others used to re secure theirs?
garmp
  • 354
  • PurchDate: 3/20
  • ModelYear: 2020 2351D
  • IntColor: Greystone
Re: Fabric on the slide out ceiling
« Reply #1 on: June 17, 2025, 10:58:41 am »
We had an edge pulling away from the trim. I use double sided Gorilla tape. So far it has held fine.
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
« Reply #2 on: June 17, 2025, 02:51:21 pm »
I've not encountered this issue, but I think I would try a spray adhesive that they use for automobile headliners....
You use the push button and tube approach that is on a can of WD40 instead of the traditional spray button. You poke a hole in the carpet with an ice pick, then insert the tube in the hole and spray glue in a few different directions. Just short taps needed. May need to do this in several places if a lot of it is sagging.  Once glue is in place press a board against the carpet, lightly wedge it in place with a brace and let it dry.
Larry
Larry
Amsoilman
  • 71
  • PurchDate: 2024
  • IntColor: Grey
« Reply #3 on: June 17, 2025, 06:55:59 pm »
That sounds like a pretty good idea with the tube, I’ve never tried it before. I do have some 3M 77 adhesive so I think I’ll try that this weekend. Thanks for the tip.
