NORCOLD INC N7XFL Polar N7X Series 2-Way AC/LP RV Refrigerator with Fan
  • 12890 Views
Well...  Our old Norcold N621L had an issue.
'n' on the display. Power down and back up, ran for a while then... 'n' and wouldn't do anything.  >(
Found the service bulletin to reset the circuit board, and went to figure out what it was. Using the diagnostics built into it, I found the thermistor on the fridge coils would read fine down to ~45 degrees, then suddenly revert to 73*.  :cool And we have to leave in a day for the next fest.
Tried all over our area, nobody with parts that old. Found it on Amazon for $8, but 2 day delivery.
Found that 50* on the coil triggered the 'watchdog' routine that eventually ends up with the dreaded 'n' on the display. If the coil doesn't get over 50*, it never worries.
ok!  2o2 Took resistance readings from the broken thermistor, and got a couple numbers off youtube vids.  Did some back of the napkin math, and figured out that about 22K of resistance from the sender should be ~45* reading. Cannibalized two 11K resistors from an old PC board, put them in series instead of the thermistor, and checked using the onboard diagnostics.
46* reading.  (cheer)  Left the temp setting on 5, put digital thermomter sensors in both the fridge and freezer, and went to the fest.
Worked GREAT! Kept 34* in the fridge, -1 in the freezer. Whole week.
But Mrs V was leery. A new fridge was in the works. Found that the NORCOLD  N7XFL was a direct replacement for the size,and was bigger!  Joy!
(  https://www.amazon.com/dp/B0BZQMJ25J )
And I had an 'off grid' friend that needed an ammonia fridge. Win win.
Local camping world wanted $2450 delivered.  :beg Amazon was about a THOUSAND less.  (nod)
So... in it came.  Used the tractor to bring it in from the road, first time seeing an Amazon trailer truck delivering to a house.
Unboxed, Installed.
WHAT A PIECE OF JUNK!!
In the camper for two days, no food. Testing.  Running, -4 freezer, 34 fridge. YES. We leave in 3 days, Mrs V can start packing it.
BUT.....
Water dripping off the freezer ceiling?!?!?! 1/4" plus frost on the back?!?  (See picture 'Adobe Express' below)
Did I perhaps leave the door slightly ajar? The gasket misaligned?
Nope. The absolute WORST build quality I have seen.
NO MORE smooth plastic seal seating area. Now its Steel. Probably powder coated, wait for rust in a year MAX. And the 45* butt joint... its an overlap. (Picture KIMG1581 below)
The bottom center piece was so misaligned, the left was a hairline crack. The right side was about 3/16. A wide open groove. (Picture KIMG1579 below)
Fridge was even worse on the groove. (Pic -1583)
The left hand side tight. So before foaming, this took a hit, and misaligned. Then was never fixed, or QC'd.  :beg
Now... the old 6.3 cubic foot N621 (see pic in the next post, I put too many here)  Look at that 20 year old SMOOTH PLASTIC RUST FREE SURFACE!   (cheer) (cheer) (cheer)
The new one is .7 CF bigger. ooOOOOooooh. Same shelves, same glass, same door shelf inserts. I dont know WHERE the extra room is.
But WOW is it doomed to fail. And the most sorrowful thing... MADE WITH PRIDE IN THE USA.   :beg  :'(  I can only assume it was a DEI hire, and their PRIDE wasn't in their work, but their gender.  (exactly) (Thanks to CC for that gem.  roflol )
I am going to give it a try for a week, and when we get home process it for a return. And fix the old one, do some restoration on the aged pieces, and reinstall. Probably for another 20 years.
I just have to find/make door panel inserts to get rid of the '70s wood look.
More detail on the install to come later on my 2350 thread. But for now...
DONT BUY THE POS NORCOLD INC N7XFL Polar N7X Series.  What crap.
(and now I have to go resize pictures for the ANTIQUE attachment rules here... 240kb?!? My old phone takes 1.5mB pics..  pyho  and it appears that preview doesnt show the pics. Sigh. Hope they show up)
Re: NORCOLD INC N7XFL Polar N7X Series 2-Way AC/LP RV Refrigerator with Fan
« Reply #1 on: February 13, 2025, 10:06:16 pm »
OMG... the picture posting here is as good as Norcold Quality Assurance.  roflol
« Reply #2 on: February 13, 2025, 10:09:52 pm »
ok, I am sick of fighting the forum posting pics. No pic of the fridge door gap, its about 5 toothpicks wide. The flat ones, not the good round ones.  roflol
Sorry for the attitude. The fridge was a PITA to take the doors off, and to replace them while in the camper. Then install (pretty easy with a lift table  ;) ) and then to find its JUNK.
Time for an adult beverage. Maybe a couple. Its gonna be a long 10 days mopping water from the freezer ceiling each day.  >(
« Reply #3 on: February 14, 2025, 07:07:38 am »
Volkemon,
It is great to hear from you again, but not for this reason.
I heed your warning..... if having trouble with our 2007 Norcold..... Fix It..... DO NOT replace it.
Thank you for your thumbs-down evaluation on the equivalent replacement, and the issue and the proper repair of the oldie but goodie.
About posting pictures.  Everyone hates it including myself.  I get around the challenge by posting all my pictures on the internet HERE ON FLICKR, then open the picture there, select the mediun 640x360 size, then post the link.  It is a lot of round-around, but I have become very adjusted to the task.  It is like playing a piano now.  My fingers know where to go without thought.
« Last Edit: February 14, 2025, 07:23:09 am by Ron Dittmer »
jimmer
  • 156
  • PurchDate: 5 / 2016
  • ExtColor: WHITE OVER BLUE
« Reply #4 on: February 18, 2025, 09:49:47 am »
Volkeman,    thanks for the heads up !     On our 2006 PC i've been wondering what to do if it fails, and now I know,    REPAIR !
