Awning tie downs
  • 16230 Views
garmp
  • 354
  • PurchDate: 3/20
  • ModelYear: 2020 2351D
  • IntColor: Greystone
Awning tie downs
« on: April 20, 2024, 05:02:51 pm »
Do you use them. If so what type? stake, ground screw type, or weights?
Also do you use snap pads on your jacks? Seems to me that they'd get in the way when folded up.
Thanks
Re: Awning tie downs
« Reply #1 on: April 20, 2024, 10:12:51 pm »
We have the old style crank-up awning with self-storing poles that attach to the side of the motorhome.  I have not yet staked them down with ropes to the ground.  I might if we stayed in one place for a very long time.
« Reply #2 on: April 21, 2024, 12:08:26 am »
I have not used tie-downs with my awning.  I would typically not have it extended in any type of heavy weather, and otherwise it seems to work well for me without tie-downs.  I have had it automatically retract on an occasion or two with a gust of wind, but that hasn't caused any issues.
I do use jack pads if not leveling on concrete, but not the clip-on type.  My pads are the commercial heavy rubber type a little larger than the jack feet.  I usually drop the jacks vertically then slide the pad in place under the foot.  It's a little awkward with my reduced mobility, but still doable, and only takes a few seconds per pad.
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
« Reply #3 on: April 21, 2024, 12:27:26 am »
When using the awning alone, I don't stake it down for 2 reasons... Easy to quick retract if a storm blows in, and to see the night sky and stars.
But if I have the screen room attached, I built it with places for standard tent stakes so that the wind doesn't blow it around. That keeps the awning from lifting.
The only time I use any kind of jack pad is in mud or sand. I have four 24 inch wood 2x8's always with me to put under the jacks if the ground is too soft. I sometimes use the wood under the rear duals if I must raise the rear end to the max jack length as there's not much traction left in the fully extended position.
Larry
Free2RV
  • Gary and Susie
  • PurchDate: P.U. 6/11/18
  • ExtColor: Graystone (FBP)
« Reply #4 on: April 21, 2024, 10:18:54 am »
We normally use 1" ratchet straps attached to screw-in anchors on our awning on our 3100.  If screw-in anchors aren't allowed at a campground or not practical to use, we will sometimes attach the straps to a picnic table or grill post.  We don't leave the awning out if it is overly windy or if a storm is approaching, but we don't want to have to worry about a gust of wind damaging the awning.
As for Jack pads, we don't use the clip-on type, but we do use pads under the jacks after they have swung down vertical.  We also try to put blocks under the tires on the low side or end of the PC so the jacks aren't lifting as much weight as they would if the blocks weren't used.
Gary
garmp
  • 354
  • PurchDate: 3/20
« Reply #5 on: April 21, 2024, 06:56:10 pm »
Free2RV, thanks for the replies. That is exactly what I was thinking of in regards to the tie downs. if it seems stormy, the awning is in. But even on a nice day a gust or two can be unsettling. I was just wonderine if anyone else was thinking like me.
And the Snap-Pads seem like they'd stick down to far when the jacks are retracted. I'm just getting lazy in me old age & don't want to have bend over that much/
Thanks to all.
