Sewage line leaking
  • 1 Replies
  • 21982 Views
kmallen
  • 12
  • PurchDate: July 2019
Sewage line leaking
« on: March 03, 2024, 11:17:21 am »
Hello!
My 2016 model has had no leaking during black/gray tank leaking until recently.  I am currently in Mexico and no RV tech is available.  Any DIY advice would be appreciated.
There is no leaking until the pump is turned on.  Then there is a fair amount only on the driver side just behind the bumper.  I looked under and found there is a pipe clamp is broken.  Unsure at one point it should be placed.  I I have two pictures but cant seem to post due to size. Would be happy to email to anyone interested
Many thanks!
Kathleen
Taildragger
Re: Sewage line leaking
« Reply #1 on: March 03, 2024, 03:11:19 pm »
Broken pipe clamps are easily replaced.  Flat-bladed screwdriver is the only tool necessary for their removal.  Any plumbing shop, auto parts store, or box store with a plumbing department is apt to inventory replacement clamps in a variety of sizes..
The broken clamp can be removed without disconnecting and removing the sewer hose.  Like the original, the replacement clamp is openable.    The worm gear drive to adjust clamping pressure also feeds an opened clamp end..  Simple and easy!
Actually, I would be surprised if your problem is solved by replacing the clamp.   Usually,  because of the long term period of eight years (2016-2024) on the hose joint, the rubber is probably bonded to the drain pipe.  In my experience they are always seized.   There might be more than the obvious casuing the leakl   Check for other damage to the connection.  Look for hairline cracks.  They can produce impressive leaks when the system is pressurized by the pump.
