electronic water heater use with less than 30 Amp
  • 9133 Views
detspcl
  • 26
  • PurchDate: april/2011
  • Model: 2900
  • ModelYear: phoenix cruiser
  • ExtColor: full body paint
« on: May 12, 2011, 07:12:33 am »
Can I use electric  on our 6 gal water heater when connected to shoreline that is LESS THAN 30amps? Just asking.....
thanks! Chuck k.
Re: electronic water heater use with less than 30 Amp
« Reply #1 on: May 12, 2011, 08:27:19 am »
Chuck;
I have used the water heater on a 20 amp circuit with no problem.
Checked in the Atwood water heater manual, gas/electric heater is rated at 1500 watts (12.5 amps).
« Last Edit: May 12, 2011, 08:46:50 am by Barry-Sue »
detspcl
  • 26
  • Model: 2900
« Reply #2 on: May 12, 2011, 03:10:01 pm »
Thanks! I will check household circuit before attempting electric use. It is an old farmhouse so breaker might flip.
regards,
chuck
JackD
  • 231
  • PurchDate: 2017 (latest)
  • Model: 2350 Sprinter
« Reply #3 on: May 13, 2011, 11:58:35 am »
Chuck - you might want to check your spec sheet --- mine draws 11 - 12.  Also, you really don't need to leave it on all the time..(before meals, showers, etc.)
Jack
