Cable tv
  • 10321 Views
Tarnold
  • 247
  • PurchDate: Dec 2019
Cable tv
« on: May 03, 2023, 01:43:29 pm »
Ok, just getting old.  Is there a physical switch on a 2014 2552 that selects over the air vs. cable.  Been thru menu /select/av/cable several times but can’t get to load cable stations.  Using the sat dish but want to see some local news.  Cable is hooked up to service post
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
Re: Cable tv
« Reply #1 on: May 03, 2023, 02:02:14 pm »
When using the antenna you need to have the antenna amplifier 12v power supply ON, and when using cable or satellite it should be OFF.
The button to turn it on or off is usually in the cabinet over the co-pilot seat (near the front TV. When it's ON there is a small green LED indicator. This one switch affects the signal for both front and rear TV (if equipped).
You probably have it ON,,, and that would interfere with cable & sat signals and make it seem like it's broken.  Hope this solves your situation!
Larry
Larry
Tarnold
  • 247
Re: Cable tv
« Reply #2 on: May 03, 2023, 04:48:04 pm »
Yes, the power was on.  Took a long time to upload all the channels but it now works (sorta of).  Few stations are half scrambled most are good.  Thank you.  Just remembering on my old chinook, there was a slide switch for OTA/cable.
LRUCH
  • 238
  • Model: 2900
Re: Cable tv
« Reply #3 on: May 03, 2023, 09:04:29 pm »
Larry
