Air bag cable
  • 5 Replies
  • 12108 Views
Rein
  • 30
  • PurchDate: 3/2022
  • ModelYear: 2022
  • IntColor: Mirstone
  • ExtColor: Indigo
Air bag cable
« on: September 29, 2022, 05:33:57 pm »
In our 2022 PC 2552, the air bag warning light stays lit.  The cable from the connector under the passenger seat had been installed on the wrong side, causing the cable to be torn when the seat was turned.  That was fixed, but the light stays on.  The entire harness under the seat was replaced, but the light still stays on.
Latest suspect: the part of the cable that passes through the carpet (see photo).
I can't crawl under the coach.  Can someone please tell me where the cable goes under the coach?
Thanks,
Rein
Re: Air bag cable
« Reply #1 on: September 29, 2022, 08:58:17 pm »
That cable might not pass thru the floor, but rather under the carpet towards the door pillar where the seat belt is.  I am not certain of it, only "thinking" that is the most likely place it is going.
« Last Edit: September 29, 2022, 09:00:02 pm by Ron Dittmer »
Rein
  • 30
  • PurchDate: 3/2022
  • ModelYear: 2022
  • ExtColor: Indigo
Re: Air bag cable
« Reply #2 on: October 03, 2022, 12:01:16 pm »
I heard back from PC:
"Wire harness goes to the rear of the seat mount along the back of the cab, and runs toward the drivers seat to the junction box on the floor."
Rein
  • 30
  • PurchDate: 3/2022
  • ModelYear: 2022
  • ExtColor: Indigo
Re: Air bag cable
« Reply #3 on: October 18, 2022, 02:34:43 pm »
After fixing the passenger side, the air bag warning light still stayed on so I took it to Ford.
Turns out the problem was also under the driver's seat.  Ford replaced the "pretensioner" and problem solved.
Rein
Re: Air bag cable
« Reply #4 on: October 20, 2022, 05:48:11 am »
Okay I'll bite. What is a pretensioner at where is it located?
Rein
  • 30
  • PurchDate: 3/2022
  • ModelYear: 2022
  • ExtColor: Indigo
Re: Air bag cable
« Reply #5 on: October 24, 2022, 08:45:48 pm »
It is part of the device that the seat belt clicks into.
Rein
