Ceiling Lights
  • 10 Replies
  • 25044 Views
Rein
  • 30
  • PurchDate: 3/2022
  • ModelYear: 2022
  • IntColor: Mirstone
  • ExtColor: Indigo
Ceiling Lights
« on: August 01, 2022, 04:41:39 pm »
Our 2022 2552 has very bright ceiling lights, no dimming capability.
Is there a better ceiling light that is dimmable and has a warm white option?
Rein
Re: Ceiling Lights
« Reply #1 on: August 01, 2022, 05:13:02 pm »
Here is the quick/easy method.  Remove the lens.  Using a black permanent marker, dab a black dot on every 4th LED to reduce the over-all light output.  If it is still too bright, dab every other one.  The dab will reduce, not eliminate the light output, so you might find yourself dabbing every LED, especially where the fixtures are in tight quarters.
The proper solution would be to disable LED circuits which would also save on battery energy.
I did the dab on my Saturn Sky interior illumination project when converting from incandescent to LED.  The LEDs for the switches and controls were otherwise blinding.  So many incandescent bulbs were burnt out so performing the conversion was an opportunity at hand.
« Last Edit: August 01, 2022, 11:48:09 pm by Ron Dittmer »
jim.godfrey
  • 292
  • PurchDate: October 2019
Re: Ceiling Lights
« Reply #2 on: August 01, 2022, 09:07:18 pm »
I installed a switch in each fixture to turn off one side of the light. I typically leave them on half unless I need extra light for a task.
This is what I used: https://www.amazon.com/gp/product/B07DWS195R/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Install was pretty easy, just drill a hole for the switch, cut one lead and solder to the switch.
parkgt
  • 56
Re: Ceiling Lights
« Reply #3 on: August 02, 2022, 08:12:53 am »
On getting our 2552 I immediately decided the bright lights had to go.  My solution was to replace the fixtures.  Besides being full dimmable with 3 color choices they look better IMO.  They are almost an exact match for the footprint of the old fixture so once installed they look stock.
https://www.amazon.com/gp/product/B09GY6ZYND/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Here are pictures showing relative dim and bright, front and back in a 2552.
Re: Ceiling Lights
« Reply #4 on: August 02, 2022, 08:26:28 am »
I REALLY like your recommendation.  I won't be making any lighting changes since we are good with what we have, but that is surely a winner of a change.  Phoenix should be mounting that one on their assembly line.
Rein
  • 30
  • PurchDate: 3/2022
  • ModelYear: 2022
  • ExtColor: Indigo
Re: Ceiling Lights
« Reply #5 on: August 02, 2022, 06:12:03 pm »
I ordered the one recommended by Parkgt.
I like the three color temperature choices, especially in the bathroom for Carol's makeup.
Rein
parkgt
  • 56
Re: Ceiling Lights
« Reply #6 on: August 02, 2022, 07:24:04 pm »
Rein,
I think you will like them.  The On/Off switch is flush with the casing making it hard to find by touch.  They can be pressed from the side and bottom.  I added small clear self-adhesive pads to both planes to make them easy to find, I actually cut a small pad in half for each surface.  You will understand when you get them.
I bought this set to pad the blinds in the bedroom so they don't clank rolling over at night.  The little square ones cut in half are perfect.
https://www.amazon.com/gp/product/B08RYZ6PKR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
mikeponiatowski
  • 28
  • IntColor: Cherry/Brown/Beige
  • ExtColor: White/Green
Re: Ceiling Lights
« Reply #7 on: August 09, 2022, 03:09:04 pm »
Just purchased a set of them.  Installed easily.  Much better lighting than stock and better than adding LED light tubes.
Amsoilman
  • 71
  • PurchDate: 2024
  • IntColor: Grey
  • ExtColor: White Grey
Re: Ceiling Lights
« Reply #8 on: January 31, 2025, 06:47:40 pm »
I took your advice and replaced all of mine with these lights, which are so nice. I also bought the little pad, which really were a good idea. Thank you.
parkgt
  • 56
Re: Ceiling Lights
« Reply #9 on: February 18, 2025, 05:52:29 pm »
Happy to see that several have tried the lights I recommended and are pleased with the lighting.    They do make a huge difference in enjoying your coach.  I also replaced the other under cabinet strip lights with dimming ones that can be switched to red for nighttime.  And I replaced the reading lamps with nicer dimming units.  Put motion activated battery powered LED strips under the bed and in some forward cabinets.  All made incremental improvements towards having pleasant and functional illumination.
MN Traveler
  • 1
  • ModelYear: 2022
Re: Ceiling Lights
« Reply #10 on: February 21, 2025, 09:45:13 am »
Please share the link to the under cabinet dimming strip lights.
Thanks
