Parallax Charger Converter
  • 1 Replies
  • 8053 Views
Funseekers
  • 50
« on: June 28, 2022, 10:10:18 am »
After much confusion, we discovered our Model year 2018 PC 2100 has the Parralyx single stage charger/converter but we can’t find the actual model # to correctly cross reference to the proper Progressive Dynamics replacement to adequately charge our battleborn batteries.
Researching the forum archives hasn’t helped us too much and Doug couldn’t be specific enough to assist.
At $200.00 an hour shop rate we want to make sure we get a correct drop in replacement so can anyone help us?
Our actual build was July to September 2017.
Model # doesn’t appear on the front panel
Thanks
Engineerlt
Re: Parallax Charger Converter
« Reply #1 on: June 28, 2022, 11:38:05 am »
Hello Its probably the Parallax 5300, like was installed in my 2017 end of year coach. I removed the converted section and installed a WFCO 9855 LIS converter which is lithium battery compatible. If you would like more info just PM me.
Very Respectfully
Lance
« Last Edit: June 28, 2022, 11:39:50 am by Engineerlt »
