Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Guest
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
Another Inverter question.
« previous
next »
Pages: [
1
Go Down
TzrNPeg
83
PurchDate: 9/27/2018
Model: 2552
ModelYear: 2019
IntColor: Greystone
ExtColor: Mostly grey (silver?) and white with swirls
on:
June 09, 2022, 05:39:46 pm »
I almost never use the inverter since I usually have an electric connection while parked. The question came up - If I'm plugged in and using the A/C, would I be able to turn on the inverter and use one of the invertor outlets without drawing on the same power as the A/C? Or do the inverter outlets automatically switch over to plugged in electric? (Does that make any sense?)
I have a 2019 2552.
Peg
PurchDate: May 2013
Model: 2552
ModelYear: 2013
IntColor: Sunlit & Cherry
ExtColor: Sunlit
Re: Another Inverter question.
Reply #1 on:
June 10, 2022, 06:17:05 am »
Good question. I think it switches but not sure and don't know how. If you don't get a definitive answer here, and if you're in the Travel Club, that would be an excellent question for the"Ask Doug" Zoom meeting on June 28th at 1:00 Eastern.
PurchDate: 03/2015
Model: 2551
ModelYear: 2015
IntColor: Nightscape/Hickory
ExtColor: White/Nightscape
Reply #2 on:
June 10, 2022, 07:12:48 am »
The inverter essentially has it's own transfer switch so if you are plugged into shore power (or running the generator) the inverter doesn't do anything, all the outlets are fed by shore power.
jim.godfrey
292
PurchDate: October 2019
Model: 2552
ModelYear: 2020
IntColor: Desert Sand
ExtColor: Nightscape w/ Burgundy
Reply #3 on:
June 10, 2022, 08:41:09 pm »
Like Don said, most inverters go into bypass mode when shore or generator power is present. Here is a pretty good explanation of how it works.:
https://www.rvtechlibrary.com/electrical/ivtr_overview.php
Pages: [
1
Go Up
« previous
next »
