Generator Panel Readout /USB cable in dashboard
  • 9086 Views
custerhank
  • 138
  • PurchDate: March/2020
  • IntColor: Brown
« on: May 21, 2022, 09:05:08 pm »
  Not getting any data readout on EMS Panel when using generator. Pretty sure I was earlier. Am I having another senior moment?
  We found a USB cable behind the dashboard which appears to be a charging cable? Everything at the dashboard seems to be working so do not think we disconnected anything. Did factory provide a USB cable? Has about a foot of slack on it.
Thanks (Again)
Custer Hank
Hank & Joyce Whitney
Custer, SD
2019 PC Model 3100
Re: Generator Panel Readout /USB cable in dashboard
« Reply #1 on: May 22, 2022, 12:22:30 am »
Hank,
My unit is a 2019 2552.  I have the hardwired (installed) EMS system as well.  My generator output does NOT read on the EMS panel.  That means that the hardwired EMS is installed between the receptacle where you hook up your outside power cable and the transfer switch where the generator output connects.
The owners manual for the EMS unit states that it can be installed (wired) either before the transfer switch (where it only monitors outside power) or after the transfer switch (where it would monitor both outside power and generator power).  Apparently Phoenix elected to install it before the transfer switch.  Not a "senior moment", but I don't think you actually saw the generator output on your EMS earlier.
Regarding the USB cable.  The Ford chassis did not have any USB outlets as OEM equipment.  In my unit (same year as yours), Phoenix installed a single USB connector on a short length of wire which can extend from the dash to charge phones, etc.  I guess they felt they should provide at least one since Ford let the E Series chassis slip behind the times technology-wise.  My 2019 E450, while a very capable RV chassis, is about 2005-era when it comes to technology.
custerhank
  • 138
  • IntColor: Brown
« Reply #2 on: May 22, 2022, 04:47:05 pm »
Mike,
  EMS Panel -our previous diesel pusher (15 years) always had a generator readout so I guess it was wishful thinking to have one on the PC. Thanks for clearing that up.
  We assumed the USB cable on the dash was for charging but, since it does not seem to do that (does not charge), thought it might have been related to some hardware up front.
Hank
Custer, SD
2019 PC Model 3100
« Reply #3 on: May 22, 2022, 07:25:47 pm »
Hank, from your description the USB pigtail matches exactly what I have in mine so I'm virtually sure that's the one Phoenix installed.  Mine charges just fine, so I can only assume that you could have a connection issue or maybe a fuse out on the circuit serving that USB.
Unfortunately I've never had occasion to trace that link to see where Phoenix wired it in, so I can't tell you immediately where to look.  It's probably pretty straightforward--just a USB connector that ties into a 12-volt feed, but tracing wiring behind that dash can be a challenge.
