another project
  • 7 Replies
  • 25772 Views
another project
« on: April 26, 2011, 08:43:14 pm »
I plan on another electric receptacle around the corner of the bed, a little easier to reach then at the bottom of the bed. If I an go up thru the wall at the end of bed I will also see about adding some Rope Lights across the top of the slide. They make for easy lighting to watch TV.
« Last Edit: July 03, 2011, 01:21:59 pm by aimee »
Re: another project
« Reply #1 on: April 28, 2011, 10:08:05 pm »
And we continue. Replaced the plug under the bed and from their wired to set up for another plug, above that a switch for the rope lights above the switch. Plan on hard wiring the rope lights. The plugs, they are great, strip the wire, push it in and tighten. Don't have to wrap the wire around the screw. I always add a small piece of wood top and bottom where a plug will go, especially on the thin walls.
« Last Edit: July 03, 2011, 01:22:40 pm by aimee »
Re: another project
« Reply #2 on: April 30, 2011, 07:57:59 pm »
Here it is finished, the new plug at the bottom, the switch in the middle, the conjunction box for the rope lights and the rope lights. The rope light make it very easy to watch TV, no light's reflecting in the TV
« Last Edit: July 03, 2011, 01:23:25 pm by aimee »
Re: another project
« Reply #3 on: April 30, 2011, 09:18:51 pm »
Billy, You done some very nice little enhancements.
I always thought rope lights would have been a real nice touch in PCs.  2o2
  • 365
  • PurchDate: 09/2011
Re: another project
« Reply #4 on: April 30, 2011, 10:27:29 pm »
billy:
Nice work.
I do not get the rope light thing though.  I might be a little slow.  How does that help with viewing the tv?
David
Re: another project
« Reply #5 on: April 30, 2011, 11:07:25 pm »
rope light give off a softer light then the fluorescence. plus there is no reflection in the tv.    best i can do
Re: another project
« Reply #6 on: May 01, 2011, 02:48:15 pm »
nice job Billy!  2o2
did you consider using one of the red, white and blue rope lights?  roflol
Re: another project
« Reply #7 on: May 01, 2011, 04:57:53 pm »
I one of our homes the master bath was Red, White and Blue, maybe there.
