Kwikee Steps Won't Stay Out
  • 1 Replies
  • 15421 Views
stanclem
  • 61
  • PurchDate: April 2022
  • ExtColor: Desert Sand
« on: May 04, 2022, 01:02:53 pm »
For the record and to possibly help someone in the future.
On the "new to us" 2015 Phoenix Cruiser 2552 the steps would ONLY follow the door no matter how the Door Switch on the wall was set.
We wanted the steps to stay out while parked, like they are designed to do.
To make a very long story short, someone installed the wrong switch in the door frame. My steps need a Normally Open switch. (When the door is open and the switch is at rest the circuit is OPEN.)
The switch installed was Normally Closed. [The N/O and N/C switches look the same you need to use an Ohm Meter to be sure which one you have.]
Apparently, the person who installed the incorrect switch switched the power wires on the motor to make it stop working backwards.  pyho
 ie with the motor leads correctly wired if you opened the door the steps would retract and when you closed the door the steps would extend.
So, with the incorrect switch and the motor wires swapped the steps will only follow the door.
If you see this behavior CHECK THE DOOR SWITCH..
This is the Normally Open switch I ordered:
https://www.amazon.com/dp/B001FQNL4U?psc=1&ref=ppx_yo2ov_dt_b_product_details
Cole Hersee 9002 Door Momentary Switch
Good luck and happy trails!
wideglide
  • 86
  • PurchDate: 6/2026
  • ExtColor: gray
Re: Kwikee Steps Won't Stay Out
« Reply #1 on: July 28, 2026, 04:07:25 pm »
To add to this....
My new to me 2011 PC had inoperable power mirrors when i got it. Troubleshooting led me to a cut wire in the area of the parking brake. Repaired that and now mirror works right. While i was in there looking around i found a blue/white wire in a bundle that had been deliberately cut. I made a temp reconnection to investigate what i may have fixed that hadnt been working before as this was a switched 12v from the ignition. Apparently PC disabled this wire because they used it through the step switch to to toggle the step lock function. When i made the connection the step lock no longer worked.
So if you notice that wire cut up behind the brake pedal area....leave it
