WiFi Boosters
  • 8 Replies
  • 14460 Views
Woodchuck
  • 85
  • PurchDate: 04/2021
WiFi Boosters
« on: February 22, 2022, 08:09:35 pm »
Do they really work? I have seen some attached at the top of the ladder. Cost & installation? Thanks, Chuck  :)
Chuck & Sheila
Re: WiFi Boosters
« Reply #1 on: February 22, 2022, 10:14:53 pm »
Chuck,
I'm going to shoot you a response, although I'm not going to be much help on this question. I had Phoenix install both a wifi booster and a cell phone booster during the build of my 2019 2552.  I wanted them to install the systems, because both setups use cables linking the external antenna to the internal broadcast point and installing those cables during the build seemed like the thing to do.
The reality is that I have only used the cell phone booster a couple of times, and I don't think I've ever tried to use the wifi booster.  The wifi units are designed to boost a local signal (such as at a campground), but I typically use my hotspot for my data connection and just haven't needed to access local wifi signals.
For general information, the wifi booster I have is a Magnadyne unit.  This Amazon link https://www.amazon.com/dp/B076JL73XS will provide info on it; although it shows to be unavailable from Amazon.  Magnadyne still lists the unit on their site at $200.  When I was searching in late 2018, that unit had about the best reviews I could find, and it was the first unit to use all 12-volt power (which simplified the installation).  In the intervening three years, there are likely other/better wifi boosters out there (I haven't had occasion to look).  By the way, it's likely that some (most) of the antennas you see on the ladder are actually cell boosters.  Although my cell antenna is mounted on the roof rack, the wifi antenna is much larger and is actually a roof mount.
Woodchuck
  • 85
Re: WiFi Boosters
« Reply #2 on: February 23, 2022, 11:22:58 am »
Thanks Mike, Sounds like the easiest thing to do would be to up my data plan & use a hotspot. Chuck  :)
Chuck & Sheila
Re: WiFi Boosters
« Reply #3 on: February 23, 2022, 01:30:34 pm »
I use a cell booster and a hotspot.  Wifi boosters are not very effective in most situations.
Taildragger
Re: WiFi Boosters
« Reply #4 on: February 23, 2022, 01:45:03 pm »
Do Wi-Fi boosters really work?  No doubt about it! Wireless boosters do work, and they work like a charm. By increasing signal strength and eliminating dead zones, the overall connection speed is better. Crucially, to use a booster, you need some kind of existing signal already there. It won't produce a brand-new signal. It solely amplifies an existing weak connection.
I use ours by mounting the receiver high enough to extend above adjacent obstacles.  Signal strength is correlated to “line of sight”.  And, since nearby oversize vehicles can be very effective obstructions, I assemble sections of PVC pipe to elevate my receiver.  The height advantage captures the internet signal, impeded only by distance, and amplifies it.
The extendible pipe tower is used “free-style” and placed wherever signal dictates.  The captured signal is carried via a length of coaxial cable to inside the Phoenix Cruiser.   The amplified signal is enhanced considerably.  Any nearby gadget can connect to it easily.
With your own router broadcasting enhanced WI Fi signal using the personalized SSID retained from the initial setup, there is an added advantage.  Plenty of flexibility!  As you inevitably switch networks, moving from campground to campground, your router retains the personalized configuration used by all your onboard devices: computers, PDA’S, phones, etc., etc..  Upon arrival at any new location, Username/Password configuration is only necessary on the boosted router.  From that point, the retained security responses in each of your multiple onboard Wi-Fi devices allows their use without having to reconfigure each.
So, no matter where I have moved, my onboard devices easily connect to the same Wi-Fi SSID configured years and thousands of miles ago.
Re: WiFi Boosters
« Reply #5 on: February 23, 2022, 07:32:13 pm »
I don't doubt your experience at all.  And absolutely being able to place the antenna higher than surrounding rigs is good also.
However, many of the campgrounds we visit or overnight boondocks at stores like Walmart have SLOW wifi.  Thus my getting a cell booster and a cellular hot spot.  The hotspot adds $10 to my Verizon bill and the 1st 15GB is at full speed (LTE+ or 5G if I want to get a new hotspot) per month and that's plenty for her tablet.  Me, my cell phone has unlimited data at full speed.
So different experience for me, but then I am not in Alaska and doubt you folks up there have near the cellular coverage we have here.
Re: WiFi Boosters
« Reply #6 on: February 23, 2022, 08:33:26 pm »
I think the key is having done enough traveling in varied areas to know what you're going to need and use for connectivity.
As a total RV newbee when I bought my unit, I didn't have that experience.  I just knew that as a fairly heavy data user I wanted to incorporate capability that would be as effective and reliable as possible.  The cost of installing both a cell and wifi booster was not a major number (compared to the price for that RV!), and it made sense to me to do it during the build.
With three years experience since then, I would not incorporate the wifi booster today for my uses.  My cell phone has hot spot capability, but I also set up a separate unlimited data package and mifi for my computer data and the combination has handled things everywhere.  I don't believe I've ever been at a location where I had a local wifi signal--but no cell signal--which is the only situation that would require the wifi booster.  I have absolutely no doubt that there are locations that probably fit that category, but I haven't hit them yet.
Like everything else in life, experience with your RV is a great teacher, and I've learned a lot!
Taildragger
Re: WiFi Boosters
« Reply #7 on: February 23, 2022, 10:00:17 pm »
If the question is about Wi Fi, I phrase my answer accordingly.
If the question is about alternatives, I can easily agree cellphone data plans are quickly becoming the preferred choice.  Cellular enabled routers capable of multiple SIMM cards, widespread signal availability, multiple carriers, inexpensive data plans make the choice easy.
WillLloyd
  • 216
  • PurchDate: Feb/2017
  • IntColor: Pebble
  • ExtColor: Grey
Re: WiFi Boosters
« Reply #8 on: February 24, 2022, 10:15:58 am »
Most campground Wi-Fi signals are not worth boosting. Their networks are typically slow. I also worry about security. Cellular hotspots are the way to go.
