Model 3100 Inverter and transfer switch location.
  • 10037 Views
TheLuvShack
  • 143
  • PurchDate: October 2016
« on: January 18, 2022, 10:37:07 pm »
Anybody know where these are located in a 3100?
Re: Model 3100 Inverter and transfer switch location.
« Reply #1 on: January 18, 2022, 10:44:48 pm »
I believe the 3100 has twin beds like the 2551/2552,if so, the inverter is under the passenger side bed, near the front.
The transfer switch (the one that switches between shore power and generator power) is located in the transition wall between the Ford cab and the side of the living area fiberglass on the driver's side.
« Reply #2 on: January 19, 2022, 06:03:19 am »
Donc13 is correct. You have to remove the bed board to access the inverter. The little control panel mounted on the transition wall is wired to it.
You have to remove the carpeted baseboard to access the transfer switch. Feel around in the carpet on the face of the baseboard and you'll find the head of a really long screw that you have to remove.
TheLuvShack
  • 143
« Reply #3 on: January 19, 2022, 09:38:09 am »
Found them! Thanks for your help!!!
WillLloyd
  • 216
  • PurchDate: Feb/2017
  • IntColor: Pebble
  • ExtColor: Grey
« Reply #4 on: January 19, 2022, 12:14:34 pm »
Look for wet spots near the transfer switch. That’s where our leak accumulated and and we didn’t see it until it was too late.
