Top wood trim for slide pushed out
  • 18 Replies
  • 30952 Views
Re: Top wood trim for slide pushed out
« Reply #15 on: October 30, 2021, 05:53:23 pm »
I have the 500:1 motors in my 2351.  It is also my understanding that the wood trim is key when stopping the slide when it is fully extended.  So far my trim frame is fine, but I would not mind if it had a few more screws holding it in place.  The spacing on the center most set of screws is a bit over 12 inches with the two outer most having a spacing of about 19 inches.
JJ
If the trim really is the stop for the slide, disregard my method to fix the top board by nailing the corner together. It really should be removed and beveled on the back side top edge so it does not hit the wall first.
Engineerlt
« Reply #16 on: October 30, 2021, 05:58:30 pm »
JJCRUISER how big is the slide on your PC? Is it similar size to the 2552? Interesting that PC used 500:1 motors. Appreciate the information.
Very Respectfully
Lance
JJCruiser
  • 131
  • PurchDate: 10/2018
  • IntColor: Nightscape
« Reply #17 on: October 30, 2021, 06:40:03 pm »
Very Respectfully
Lance
I am not real familiar with the 2552, but based on the floor plan diagrams for the 2552 and 2351 on the Phoenix Product tab, it appears the slides are the same.
JJ
JJCruiser
  • 131
« Reply #18 on: October 30, 2021, 06:59:39 pm »
Very Respectfully
Lance
JJ
Attached is a photo of one of my slide motors.
