PC YouTube Video
  • 13470 Views
PC YouTube Video
« on: October 24, 2021, 10:25:20 am »
Sorry if this has already been posted but I just ran across this video.  It does a good job of highlighting the features of the Phoenix Cruiser in general and the 2552 in particular.
https://youtu.be/3N-_E0RYnqg
Re: PC YouTube Video
« Reply #1 on: October 24, 2021, 04:43:18 pm »
Are the fiberglass walls actually laminated over plywood or foam cores?
Cool hat and polo shirt  2o2 . When can we buy those?
« Reply #2 on: October 24, 2021, 08:03:41 pm »
As I understood back in 2007, the make-up of PC walls are as follows.
1) Outside is a thick gel-coat fiberglass sheet, maybe 1/4" thick.
2) Core is aluminum studs, alloy framing for large openings, and block foam insulation
3) Inside is prefinished tempered hardboard
The sandwich is vacu-bonded together, an interesting process where the components are glued and assembled, then somehow quickly placed in a huge bag and the air is sucked out.  It is a process not very different to linen bags and a vacuum cleaner at home, used for compact storage of huge bulky fluffy items.
The materials for the roof is different.
1) Outside is a thin layer of fiberglass sheathing
2) Supporting it is one or more layers of thin Luan plywood
3) Core is curved aluminum rafters, framed openings, and block foam insulation
4) Inside has a fabric, later a foam-backed vinyl.  I don't know the supporting material.
Please correct any inaccuracies.
« Last Edit: October 24, 2021, 08:14:41 pm by Ron Dittmer »
JKSan
  • 21
  • PurchDate: 3-13-2021
  • ModelYear: 2021
  • IntColor: Nightscape
« Reply #3 on: October 25, 2021, 08:34:00 am »
Thanks for posting the video.  I was hoping PC would have something from the Hershey show.  It was good to "meet" Tina.  :)
« Reply #4 on: October 26, 2021, 09:15:15 am »
That video makes me want a brand new PC... I wonder if they would give me $130k on my 2010 2551 trade-in!
« Last Edit: October 26, 2021, 09:26:20 am by 2 Lucky »
« Reply #5 on: October 26, 2021, 05:59:00 pm »
2lucky….. considering the current rate of inflation that sounds like a reasonable expectation.
