Dinette Table top Replacement
  • 7 Replies
  • 13293 Views
« on: April 17, 2011, 05:01:05 pm »
I have a PC 2100-2005, and the dinette tabletop that acts as a support for the bed, has broken.  It is solid maple laminated together, 29"x30"x7/8".  I can cut one down.  Does anyone know where to get a replacment top?  Thanks.
Trudy
  • 116
  • PurchDate: 1-10
  • Model: 2950
Re: Dinette Table top Replacement
« Reply #1 on: April 17, 2011, 07:19:25 pm »
I would contact Phoenix Cruiser for a new one. I'm waiting to hear what a special sized one would cost for our PC (going to add a flip-up table). They got back with me right away after I emailed. Good luck!
Trudy
  • 5744
« Reply #2 on: April 18, 2011, 11:10:17 am »
Often a good piece of wood like a solid table top breaks cleanly and can be repaired successfully as follows.
- Buy carpenter's wood glue from any home improvement store.  A common brand is Elmer's though any brand is fine.
- Apply the glue completely covering both broken raw-wood surfaces.
- Clamp the two toegther for the right bond, squeezing out excess glue
This is a good method using cheap pipe clamps.
- With a hot wet rag, wipe off excess glue, it cleans off well with warm/hot water.
- Check for alignment of the two pieces to assure a nice bump-free alignment, adjust as neccessary
- After a few days in the clamps, it's good, but since it broke once, I strongly recommend screwing two hard wood wooden rails on the bottom for increased strength.
If this is not somthing you can handle, and you do not know anyone who can do this, then as suggested, contact the factory and they will sell you another one.
« Last Edit: April 18, 2011, 11:28:39 am by ron.dittmer »
« Reply #3 on: April 18, 2011, 12:11:01 pm »
Richard (and Trudy also) you are asking us where to find someplace but you are not telling us where you are. In your profile you can fill out the info about your PC and a general location of where you live. Full timing is a location.  2o2
Like Ron said you can fix the table top yourself, call the factory or look in the yellow pages for a kitchen cabinet builder. ;)
Trudy
  • 116
  • PurchDate: 1-10
  • Model: 2950
« Reply #4 on: April 18, 2011, 08:38:34 pm »
Sorry Tom, we're in IL. I'll get that added!
Trudy
  • 5744
« Reply #5 on: April 18, 2011, 09:52:31 pm »
Send me a PM with your exact location.  If we are close, drop it by and I will see what I can do, assuming the wood has not split badly.  A clean break is most hopeful.  Include a picture or two.  No charge for me giving it a try.  I could add some dowel rods too if it's clean.  Biscuits are better but I am not equipped for that.
« Last Edit: April 18, 2011, 09:54:19 pm by ron.dittmer »
« Reply #6 on: April 19, 2011, 08:00:11 am »
I think I confused things. Richard is the one with the broken table.
To add one's location, just go into your profile (click on Profile above, on the line with home, help etc.) and edit it. The location is near the bottom.
« Last Edit: April 19, 2011, 08:02:13 am by TomHanlon »
  • 5744
« Reply #7 on: April 19, 2011, 08:24:46 am »
Oops, yes, Richard2 is the one.  Sorry.  Still my offer is open if he is close by.
