50 amp 90* plug REPLACEMENT
  • 7978 Views
Tarnold
  • 247
  • PurchDate: Dec 2019
« on: August 28, 2021, 11:10:25 am »
Looking to swap my current plug for a 90 degree, to lessen weight drag when plugged in.  Found lots of 90 * adapters 50 to 50, with short cords.  Really just want to replace, not extend the cord.  Would need the locking ring.  Searched other forums, and the net, but nothing I can find.
Re: 50 amp 90* plug REPLACEMENT
« Reply #1 on: August 28, 2021, 01:32:12 pm »
There are several listed on Amazon
Tarnold
  • 247
« Reply #2 on: August 28, 2021, 03:57:25 pm »
Found lots of those. Really only want to cut off my old “straight” female plug and ADD a 90* in its place
« Reply #3 on: August 28, 2021, 04:06:26 pm »
It's not that much weight, just run the cable straight to the ground.  Or, get one of these right angle adapters plus a standard 30' or 50' 50amp plug in cable.
That will give you the right angle and essentially the same total cable length.
« Last Edit: August 28, 2021, 04:08:06 pm by donc13 »
