Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
Side door hinge
« previous
next »
Pages: [
1
Go Down
Side door hinge
Gixxerkid3
Side door hinge
on:
July 25, 2021, 11:18:06 pm »
Hi all, wondering if anyone has a photo (up close and detailed) of the coach door hinge from the outside? I noticed on our trip last week that the hinge pin has a small amount of movement which allows the door to become sloppy so to speak. I put a washer on the underside of the hinge and bolted it back up from the bottom with the single bolt. I am just curious what washers and spacers are supposed to be there. I do know there are spacer washers for figment but just curious. I did clean and grease the hinge pin with waterproof grease.
Thanks all.
Tarnold
247
PurchDate: Dec 2019
ModelYear: 2014
Re: Side door hinge
Reply #1 on:
July 26, 2021, 09:53:04 am »
My door has also developed a little sag. The paint has started to rub on the bottom jam, opposite of the hinge. Tried to lift and insert split washer under hinge. Worked for a few openings, but sone downward pressure kicked the split washer out.
JSanford
36
ModelYear: 2021
IntColor: Nightscape
ExtColor: Nightscape
Re: Side door hinge
Reply #2 on:
July 27, 2021, 06:43:08 pm »
Here is a close up of my hinge. Sorry, it's from the inside but maybe it will help.
Gixxerkid3
Re: Side door hinge
Reply #3 on:
July 27, 2021, 11:16:34 pm »
That works. Thanks
Gixxerkid3
Re: Side door hinge
Reply #4 on:
July 27, 2021, 11:28:00 pm »
I added a washer. Problem solved.
Pages: [
1
Go Up
« previous
next »
