Replacement window corner plastic angles
  • 7 Replies
  • 13766 Views
zolman
  • 109
  • PurchDate: 12/29/2021
  • ExtColor: white/gray/black
« on: June 20, 2021, 11:05:28 pm »
I just replaced all my exterior window rubber weather stripping. All my stripping had shrunk and was obviously damaged by heat and sun. While doing that I saw the almost all of the plastic corners of my screens are broken.
Has anyone replaced those plastic corners?
Where can the corners be purchased from?
« Last Edit: June 21, 2021, 02:27:54 am by zolman »
Re: Replacement window corner plastic angles
« Reply #1 on: June 21, 2021, 03:52:50 am »
Search the forum for an old window glazing thread which links to  a  company  that supplies window glazing sample kits and all kinds of rv window parts too. I can’t recall their name because I ordered the glazing from Phoenix instead, sorry.
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
« Reply #2 on: June 21, 2021, 10:56:41 am »
I've been wanted to do this but I guess I am to stupid to figure out which weather stripping to buy.  Do you have a part number and or any info to purchase?
Thanks, Bob
Didn't mean to hi-jack your thread.
zolman
  • 109
« Reply #3 on: June 21, 2021, 10:50:00 pm »
I ordered the glazing from PC. They now only sell black. I first did order samples from Pellard Enterprises. But it was still difficult to get a perfect match to the OEM.
It was quite a job to put in. But my PC needed it since my glazing shrunk due to sun damage.
You have to do it on a warm day and soak the glazing in hot water before trying to put it in place. I also used a lot of soap to make sure it slid into the proper groove.
« Last Edit: June 21, 2021, 10:56:14 pm by zolman »
« Reply #4 on: June 22, 2021, 01:47:51 am »
Pellard is the place I was referring to. Search their online store for screen  corners.
zolman
  • 109
« Reply #5 on: June 24, 2021, 11:04:04 pm »
PC uses Hehr windows. The plastic corners are not available from PC, but the can be found on the internet in various sites and even Amazon.
I found RV Parts Center, who sells the corners in pairs to be the best price.
« Reply #6 on: June 25, 2021, 01:02:06 pm »
Are your screens falling apart because the plastic corner brackets have become brittle, damaged from the sun?
« Last Edit: June 25, 2021, 01:05:09 pm by Ron Dittmer »
« Reply #7 on: June 28, 2021, 08:39:59 am »
https://www.rvpartscenter.com/shop-by-categories/list1/hardware-locks-levels/rv-window-parts/rv-window-screen-parts/hehr-rv-window-screen-corner-2-pk-black-2-5-inch-radius-detail
