Leak on top of HWH Kickdown Actuator
  • 0 Replies
  • 7218 Views
KEB
  • 69
  • PurchDate: March 2021
  • ModelYear: 2019 2910T
« on: June 06, 2021, 11:08:58 pm »
My right front HWH leveling jack is leaking. Leak appears to be coming from the threads around the allen head screw on top of the kick down actuator cylinder. Does anyone know if this is simply a plug in the top of the cylinder?
I tried tightening and loosening it with no success with zero pressure on the system.  It also appears to be an odd size. A 1/4 inch allen fits it best but still a little loose, 5/16" is too big. I tried metric sizes. 6 mm is too small, 7 mm too big. I will chase down a 9/32" to see if that fits.
Has anyone seen this before?
