Speedometer
  • 11338 Views
Janey
  • 112
  • PurchDate: 8/19/14
  • ExtColor: Cafe
Speedometer
« on: April 20, 2021, 12:22:20 pm »
We had 2 coils and spark plugs replaced - 70 miles later our speedometer went wacko.   Registers 80 and our gps says 60.  I know I wasn’t going 80!  What would cause this and can I fix it myself.
Janey (resting and relaxing at Lake Point SP  in Eufala, Alabama)
Re: Speedometer
« Reply #1 on: April 20, 2021, 12:40:43 pm »
Speedometer is connected to the transmission (physically or electronicly) and has nothing to do with spark plugs or coils.  I suspect (but don't know) in 2014 it's all electronic, meaning the error is in either the vehicle engine/drive train computer or the speedometer itself.  Especially since it was "70 miles later" from the ignition fix before the speedometer whacked out.
That would indicate the need for a trained mechanic with a diagnostic computer to locate the error.
Out of curiosity, does the tachometer also seem to read high?
Janey
  • 112
  • ExtColor: Cafe
Re: Speedometer
« Reply #2 on: April 20, 2021, 12:45:20 pm »
We’re leaving sat am and will check then.  The motor was running great.
The engine light is not on.
J
Re: Speedometer
« Reply #3 on: April 20, 2021, 10:21:43 pm »
I believe the speedometer is not rotating-cable-controlled, but rather electronically controlled.  Before running to a mechanic, I would disconnect all batteries and leave it rest for an hour, then reconnect.  It's like rebooting your home computer.  Maybe you will get lucky and it clears it's head.
Janey
  • 112
  • ExtColor: Cafe
Re: Speedometer
« Reply #4 on: April 24, 2021, 10:46:02 pm »
Well, I’ll be @#$&!    Left campground this am and it’s fine!    I’m thinking this little Moho has a mind of her own and loves to play tricks!
Janey (happy and content at a brewery in Alabaster,Alabama- Harvest Hosts)
